RSB building problem
Sat Mar 8 14:01:17 UTC 2014
See if you have cvs. If not, install it.
-Gedare
On Sat, Mar 8, 2014 at 7:33 AM, Zhenxing Zhang <harbor0727 at gmail.com> wrote:
> There is a problem as follow when I build rtems 4.11 toolchains by RSB in
> ubuntu 12.04.
> rerber at Rerber:~/rtems/rsb/rtems$ sudo ../source-builder/sb-set-builder
> --log=l-arm.txt --prefix=/opt/rtems-4.11 4.11/rtems-arm
> [sudo] password for rerber:
> RTEMS Source Builder - Set Builder, v0.2.0
> Build Set: 4.11/rtems-arm
> Build Set: 4.11/rtems-autotools.bset
> Build Set: 4.11/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> package: autoconf-2.69-x86_64-linux-gnu-1
> building: autoconf-2.69-x86_64-linux-gnu-1
> config: tools/rtems-automake-1.12.6-1.cfg
> package: automake-1.12.6-x86_64-linux-gnu-1
> building: automake-1.12.6-x86_64-linux-gnu-1
> cleaning: autoconf-2.69-x86_64-linux-gnu-1
> cleaning: automake-1.12.6-x86_64-linux-gnu-1
> Build Set: Time 0:00:09.893937
> Build Set: 4.11/rtems-autotools-base.bset
> installing: autoconf-2.69-x86_64-linux-gnu-1 -> /opt/rtems-4.11
> installing: automake-1.12.6-x86_64-linux-gnu-1 -> /opt/rtems-4.11
> Build Set: Time 0:00:06.583940
> Build Set: Time 0:00:16.482242
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-linux-gnu-1
> building: expat-2.1.0-x86_64-linux-gnu-1
> config: tools/rtems-binutils-2.24-1.cfg
> package: arm-rtems4.11-binutils-2.24-1
> building: arm-rtems4.11-binutils-2.24-1
> config: tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
> package: arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
> download: http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz ->
> sources/mpc-0.8.2.tar.gz
> download: ftp://ftp.gnu.org/gnu/gmp/gmp-5.0.5.tar.bz2 ->
> sources/gmp-5.0.5.tar.bz2
> building: arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
> Build Set: Time 0:03:35.173633
> error: shell cmd failed: /bin/sh -ex
> /home/rerber/rtems/rsb/rtems/build/arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/doit
> Build FAILED
> Why? Thanks!
> rtems-users mailing list
> rtems-users at rtems.org
