RSB building problem
Zhenxing Zhang
harbor0727 at gmail.com
Sun Mar 9 13:35:03 UTC 2014
This is the infomation about error in my log file(l-arm.txt):
+ cd
/home/rerber/rtems/rsb/rtems/build/arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
+ /bin/rm -f gcc-4.8.2/newlib
+ ln -s
/home/rerber/rtems/rsb/rtems/build/arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/newlib-2.1.0/newlib
gcc-4.8.2/newlib
+ source_dir_20=mpfr-3.0.1
+ cd
+ /bin/bzip2 -dc /home/rerber/rtems/rsb/rtems/sources/mpfr-3.0.1.tar.bz2
+ /bin/tar -xvvf -
bzip2: Compressed file ends unexpectedly;
perhaps it is corrupted? *Possible* reason follows.
bzip2: Success
Input file =
/home/rerber/rtems/rsb/rtems/sources/mpfr-3.0.1.tar.bz2, output file =
(stdout)
It is possible that the compressed file(s) have become corrupted.
You can use the -tvv option to test integrity of such files.
You can use the `bzip2recover' program to attempt to recover
data from undamaged sections of corrupted files.
/bin/tar: This does not look like a tar archive
/bin/tar: Exiting with failure status due to previous errors
Build Set: Time 0:02:12.861282
error: shell cmd failed: /bin/sh -ex
/home/rerber/rtems/rsb/rtems/build/arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/doit
I don't known what reason the error is? Thank you!
2014-03-08 22:03 GMT+08:00 Chirayu Desai <chirayudesai1 at gmail.com>:
> Hi,
> Can you attach the log file (l-arm.txt, in the same directory)
> That should tell us why it failed.
> -Chirayu
> On Mar 8, 2014 6:05 PM, "Zhenxing Zhang" <harbor0727 at gmail.com> wrote:
>> There is a problem as follow when I build rtems 4.11 toolchains by RSB in
>> ubuntu 12.04.
>> rerber at Rerber:~/rtems/rsb/rtems$ sudo ../source-builder/sb-set-builder
>> --log=l-arm.txt --prefix=/opt/rtems-4.11 4.11/rtems-arm
>> [sudo] password for rerber:
>> RTEMS Source Builder - Set Builder, v0.2.0
>> Build Set: 4.11/rtems-arm
>> Build Set: 4.11/rtems-autotools.bset
>> Build Set: 4.11/rtems-autotools-internal.bset
>> config: tools/rtems-autoconf-2.69-1.cfg
>> package: autoconf-2.69-x86_64-linux-gnu-1
>> building: autoconf-2.69-x86_64-linux-gnu-1
>> config: tools/rtems-automake-1.12.6-1.cfg
>> package: automake-1.12.6-x86_64-linux-gnu-1
>> building: automake-1.12.6-x86_64-linux-gnu-1
>> cleaning: autoconf-2.69-x86_64-linux-gnu-1
>> cleaning: automake-1.12.6-x86_64-linux-gnu-1
>> Build Set: Time 0:00:09.893937
>> Build Set: 4.11/rtems-autotools-base.bset
>> installing: autoconf-2.69-x86_64-linux-gnu-1 -> /opt/rtems-4.11
>> installing: automake-1.12.6-x86_64-linux-gnu-1 -> /opt/rtems-4.11
>> Build Set: Time 0:00:06.583940
>> Build Set: Time 0:00:16.482242
>> config: devel/expat-2.1.0-1.cfg
>> package: expat-2.1.0-x86_64-linux-gnu-1
>> building: expat-2.1.0-x86_64-linux-gnu-1
>> config: tools/rtems-binutils-2.24-1.cfg
>> package: arm-rtems4.11-binutils-2.24-1
>> building: arm-rtems4.11-binutils-2.24-1
>> config: tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
>> package: arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
>> download: http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz ->
>> sources/mpc-0.8.2.tar.gz
>> download: ftp://ftp.gnu.org/gnu/gmp/gmp-5.0.5.tar.bz2 ->
>> sources/gmp-5.0.5.tar.bz2
>> building: arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
>> Build Set: Time 0:03:35.173633
>> Build FAILED
>> Why? Thanks!
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140309/6fbf2916/attachment-0001.html>
