RSB building problem
Joel Sherrill Joel.Sherrill at OARcorp.com
Sun Mar 9 14:36:56 UTC 2014
On Mar 9, 2014 8:34 AM, Zhenxing Zhang <harbor0727 at gmail.com> wrote:
> This is the infomation about error in my log file(l-arm.txt):
> + cd /home/rerber/rtems/rsb/rtems/build/arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
> + /bin/rm -f gcc-4.8.2/newlib
> + ln -s /home/rerber/rtems/rsb/rtems/build/arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/newlib-2.1.0/newlib gcc-4.8.2/newlib
> + source_dir_20=mpfr-3.0.1
> + /bin/bzip2 -dc /home/rerber/rtems/rsb/rtems/sources/mpfr-3.0.1.tar.bz2
> + /bin/tar -xvvf -
> bzip2: Compressed file ends unexpectedly;
>         perhaps it is corrupted?  *Possible* reason follows.
> bzip2: Success
>         Input file = /home/rerber/rtems/rsb/rtems/sources/mpfr-3.0.1.tar.bz2, output file = (stdout)
> It is possible that the compressed file(s) have become corrupted.
> You can use the -tvv option to test integrity of such files.
> You can use the `bzip2recover' program to attempt to recover
> data from undamaged sections of corrupted files.
> /bin/tar: This does not look like a tar archive
> /bin/tar: Exiting with failure status due to previous errors
> Build Set: Time 0:02:12.861282
> error: shell cmd failed: /bin/sh -ex  /home/rerber/rtems/rsb/rtems/build/arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/doit
> I don't known what reason the error is? Thank you!
Delete that file and try again. Maybe there was a bad or interrupted download.
> 2014-03-08 22:03 GMT+08:00 Chirayu Desai <chirayudesai1 at gmail.com>:
>> Hi,
>> Can you attach the log file (l-arm.txt, in the same directory)
>> That should tell us why it failed.
>> -Chirayu
>> On Mar 8, 2014 6:05 PM, "Zhenxing Zhang" <harbor0727 at gmail.com> wrote:
>>> There is a problem as follow when I build rtems 4.11 toolchains by RSB in ubuntu 12.04.
>>> rerber at Rerber:~/rtems/rsb/rtems$ sudo ../source-builder/sb-set-builder --log=l-arm.txt --prefix=/opt/rtems-4.11 4.11/rtems-arm
>>> [sudo] password for rerber:
>>> RTEMS Source Builder - Set Builder, v0.2.0
>>> Build Set: 4.11/rtems-arm
>>> Build Set: 4.11/rtems-autotools.bset
>>> Build Set: 4.11/rtems-autotools-internal.bset
>>> config: tools/rtems-autoconf-2.69-1.cfg
>>> package: autoconf-2.69-x86_64-linux-gnu-1
>>> building: autoconf-2.69-x86_64-linux-gnu-1
>>> config: tools/rtems-automake-1.12.6-1.cfg
>>> package: automake-1.12.6-x86_64-linux-gnu-1
>>> building: automake-1.12.6-x86_64-linux-gnu-1
>>> cleaning: autoconf-2.69-x86_64-linux-gnu-1
>>> cleaning: automake-1.12.6-x86_64-linux-gnu-1
>>> Build Set: Time 0:00:09.893937
>>> Build Set: 4.11/rtems-autotools-base.bset
>>> installing: autoconf-2.69-x86_64-linux-gnu-1 -> /opt/rtems-4.11
>>> installing: automake-1.12.6-x86_64-linux-gnu-1 -> /opt/rtems-4.11
>>> Build Set: Time 0:00:06.583940
>>> Build Set: Time 0:00:16.482242
>>> config: devel/expat-2.1.0-1.cfg
>>> package: expat-2.1.0-x86_64-linux-gnu-1
>>> building: expat-2.1.0-x86_64-linux-gnu-1
>>> config: tools/rtems-binutils-2.24-1.cfg
>>> package: arm-rtems4.11-binutils-2.24-1
>>> building: arm-rtems4.11-binutils-2.24-1
>>> config: tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
>>> package: arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
>>> download: http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz -> sources/mpc-0.8.2.tar.gz
>>> download: ftp://ftp.gnu.org/gnu/gmp/gmp-5.0.5.tar.bz2 -> sources/gmp-5.0.5.tar.bz2
>>> building: arm-rtems4.11-gcc-4.8.2-newlib-2.1.0-1
>>> Build Set: Time 0:03:35.173633
>>> Build FAILED
>>> Why? Thanks!
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140309/1be754ee/attachment-0001.html>
