libbsd usb01 test
Sebastian Huber
Fri Mar 14 08:14:22 UTC 2014
Hello,
the USB part in libbsd has received no testing and I doubt it will work out of
the box. It should be easily possible to use QEMU targets with an OHCI or EHCI
USB host controller.
On 2014-03-13 17:51, Sergio G.M. wrote:
> Hello,
> I have noticed that the usb01 test from libbsd does not run as part of 'make
> run_tests'.
> Is it possible to run the test on qemu?
> I had a look at the README in the USB01 directory and it refers to bug 1601
> 'USB stack port from FreBSD 8.0'.
> Is the current USB stack a port from 8.0 or 9.2 (libbsd.txt)?
> Has this test been run on QEMU?
> Does it requires a bsp other than realview-pbx-a9 (maybe lpc24xx or mpc83xx
> based bsp)?
> King regards,
> Sergio
> rtems-users mailing list
> rtems-users at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
