source builder issue (unstable: expat-2.1.0-1 missing)
Gedare Bloom
gedare at rtems.org
Mon Mar 17 17:41:26 UTC 2014
On Mon, Mar 17, 2014 at 11:12 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 3/17/2014 2:25 AM, Karel Gardas wrote:
>> Yes, like you I've been also able to build non-"unstable" tools for both
>> sparc and sparc64. The only reason why I attempted to build unstable
>> stuff is that both sis and qemu/leon3 have not worked for me. In case of
>> sis, it looks like a combination of user error where I assumed that simple:
>> sparc-rtems4.11-sis
>> ./sparc-rtems4.11/c/sis/testsuites/samples/hello/hello.exe
>> go
>> should run, but instead of it I just get:
>> sis> go
>> resuming at 0x02000000
>> IU in error mode (257)
>> 4 02000000 00000000 Address 0x0000000002000000 is out of bounds.
>> Now, I know that I need to load the file like:
>> sis> load ./sparc-rtems4.11/c/sis/testsuites/samples/hello/hello.exe
>> sis> go
> rtems-testing/sim-scripts hides the variances in a lot of simulators. It
> also makes
> it much more consistent to invoke one to run a test.
> Chris Johns has started a new generation of the same idea in Python. It
> has better
> support for automating testing on real hardware but doesn't support as many
> BSPs or features yet.
See [1]. It supports sparc/sis.
[1] http://wiki.rtems.org/wiki/index.php/RTEMS_Tester
Gedare
>> *** HELLO WORLD TEST ***
>> Hello World
>> *** END OF HELLO WORLD TEST ***
>> 128835 02001f38 91d02000 Address 0x0000000002001f38 is out of bounds.
>> but still this (for novice misleading) error message at the end remains.
>> With Qemu/Leon3 the story is probably a little bit different, I've seen
>> on the mailing list some messages about a topic and although using qemu
>> 2.0.0rc0 it may be the case that not all Sebastian's patches are in in
>> order to have vanilla Leon3 BSP running...
>> Thanks!
>> Karel
>> On 03/17/14 12:19 AM, Gedare Bloom wrote:
>>> Do the non-"unstable" tools work for you? I don't know what the
>>> unstable signifies. I use Centos 6.5 and just built my tools
>>> (4.11/rtems-sparc and 4.11/rtems-sparc64) last week successfully.
>>> -Gedare
>>> On Sun, Mar 16, 2014 at 1:11 PM, Karel Gardas<karel.gardas at centrum.cz> wrote:
>>>> Hello,
>>>> while trying source builder on CentOS 6.x on AMD64 machine I've hit
>>>> following issue:
>>>> ../source-builder/sb-set-builder --log=sparc.log
>>>> --prefix=/home/karel/sfw/rtems-sparc-head unstable/4.11/rtems-sparc.bset
>>>> RTEMS Source Builder - Set Builder, v0.2.0
>>>> Build Set: unstable/4.11/rtems-sparc.bset
>>>> error: unstable/4.11/rtems-sparc.bset:17: cannot find file: expat-2.1.0-1
>>>> Build FAILED
>>>> this is using today's source buidler head attempting to build RTEMS
>>>> unstable/4.11 tools.
>>>> Is there anything I may done in order to fix that?
>>>> Thanks!
>>>> Karel
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
