potential GSOC project: Improve the Raspberry Pi BSP
Andre Marques andre.lousa.marques at gmail.com
Wed Mar 19 19:59:56 UTC 2014
Hello Alan,
I have decided to go with the framebuffer instead of the USB support.
Will update the proposal with this.
Before GSOC I am considering to look at the SD card access through the
onboard card reader. What do you think?
--André Marques.
On 03/19/14 00:56, Alan Cudmore wrote:
> Hi André,
> I agree about the USB stack. I am not even sure about how to integrate
> a driver that depends on the FreeBSD USB stack.
> The GPIO driver from Pierre is the one I was referring to. I don't
> think anyone ever made a decision on how to integrate the GPIO driver.
> If we have macros in the BSP header files then the GPIO can be
> programmed with the simple macros or the driver that Pierre wrote. If
> the project decides to use the GPIO device model for other BSPs, then
> the generic driver code can be moved to a shared directory at a later
> date.
> Thanks for the update,
> Alan
> On Tue, Mar 18, 2014 at 11:04 AM, Andre Marques
> <andre.lousa.marques at gmail.com <mailto:andre.lousa.marques at gmail.com>>
> wrote:
>     Hello,
>     about the USB driver port from FreeBSD I am finding it difficult
>     to gauge how much work it would involve, so I will follow your
>     suggestion and look at something else.
>     As for GPIO I belive the work that has been done is this:
>     https://github.com/pficheux/raspberry_pi/tree/master/RTEMS/gpio_driver
>     Am I right?
>     I also found a discussion on the best way of implementing the driver
>     http://www.rtems.org/pipermail/rtems-users/2013-October/012059.html
>     but i am not sure if that came to a decision.
>     Meanwhile I will update the proposal with some basic info on the
>     drivers.
>     --André Marques.
>     On 03/14/14 13:16, Andre Marques wrote:
>>     Hello,
>>     On 03/14/14 02:33, Alan Cudmore wrote:
>>>     Andre,
>>>     I think your project proposal looks good, but I wonder if
>>>     including USB support is too much. There are low level "bare
>>>     metal" USB examples out there for the Raspberry Pi, and that may
>>>     serve as a starting point, but I think a real USB implementation
>>>     will use the BSD library that has been ported to RTEMS. It may
>>>     be possible, since there is a FreeBSD port to the Raspberry Pi.
>>>     Maybe others can help here.
>>     I will take a look into this.
>>>     If you think that GPIO, SPI, and I2C are not enough, then you
>>>     could always look at the framebuffer or SD card access.
>>     Yes, right now I am trying to clarify everything the best I can
>>     so I don't end up with a lot more (or less) work than I can handle.
>>>     Finally, it may be necessary to have an Raspberry Pi and a few
>>>     peripherals. For example, I have an inexpensive I2C compass
>>>     module that I use with linux, and I have a breadboard wired up
>>>     with LEDs to test GPIO.
>>     Right now I have access to a Raspberry Pi at the university, not
>>     sure about the peripherals though. Anyway, if this projects
>>     really goes forward I will get myself a raspberry and peripherals
>>     (I have already some other components, like a breadboard, leds,
>>     wire, etc).
>>>     Thanks,
>>>     Alan
>>>     On Thu, Mar 13, 2014 at 8:32 PM, Alan Cudmore
>>>     <alan.cudmore at gmail.com <mailto:alan.cudmore at gmail.com>> wrote:
>>>         I'm glad there is interest in this project. Andre, I will
>>>         read your proposal and provide feedback.
>>>         Joel, I was on the melange site and the system recognizes my
>>>         account. Do I need to do anything to be a mentor for RTEMS?
>>>         Alan
>>>         On Thu, Mar 13, 2014 at 7:31 PM, Andre Marques
>>>         <mailto:andre.lousa.marques at gmail.com>> wrote:
>>>             It is now on melange too.
>>>             --André Marques.
>>>             On 03/13/14 23:21, Hesham Moustafa wrote:
>>>>             Hi Andre,
>>>>             I quote from RTEMS SoC page :
>>>>             "GSOC STUDENTS! PLEASE FILL IN THE APPLICATION AT
>>>>             http://www.google-melange.com! YOU CAN EDIT UNTIL THE
>>>>             DEADLINE! BUT YOU WILL NOT GET A SLOT IF YOU DO NOT
>>>>             APPLY THROUGH Google!!!"
>>>>             Regards,
>>>>             Hesham
>>>>             On Fri, Mar 14, 2014 at 1:16 AM, Andre Marques
>>>>                 Hello,
>>>>                 I just posted the first proposal draft for
>>>>                 "Raspberry Pi BSP Peripherals " in the RTEMS Wiki
>>>>                 http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode
>>>>                 Any feedback is more than welcome. Should I post it
>>>>                 already in melange too?
>>>>                 --André Marques.
>>>>                 On 03/13/14 15:26, Joel Sherrill wrote:
>>>>>                 On 3/13/2014 9:46 AM, Andre Marques wrote:
>>>>>>                 Hello,
>>>>>>                 I would be very interested in working in this
>>>>>>                 project because I'm currently trying to work with
>>>>>>                 Raspberry Pi and RTEMS for my undergraduate
>>>>>>                 thesis, so this could be a great followup to that
>>>>>>                 for the summer.
>>>>>>                 I will need to do some reseach on it before
>>>>>>                 making a proposal (the time is also gettting
>>>>>>                 shorter), but will post a proposal draft very soon.
>>>>>                 This would be a great area to work. As Alan says,
>>>>>                 the list is likely too much for
>>>>>                 one student, so it seems likely that the work
>>>>>                 could be divided for two students
>>>>>                 working on different parts.
>>>>>                 For the Pi Master list, I would like to add the
>>>>>                 Geert board. That looks like something
>>>>>                 of interest to RTEMS folks.
>>>>>                 --joel
>>>>>>                 --André Marques.
>>>>>>                 On 03/13/14 11:23, Alan Cudmore wrote:
>>>>>>>                 ( I posted this to the rtems-devel list by
>>>>>>>                 mistake, my apologies for the duplicate message )
>>>>>>>                 f there are still potential GSOC students out
>>>>>>>                 there looking for a project, I would like to
>>>>>>>                 offer a potential project to work on: Improving
>>>>>>>                 the Raspberry Pi BSP. I would be happy to mentor
>>>>>>>                 a student for this project. Below is my
>>>>>>>                 description for the task.
>>>>>>>                 Thanks,
>>>>>>>                 Alan
>>>>>>>                 One of the RTEMS Open Projects is to contribute
>>>>>>>                 a BSP or Board Support Package for readily
>>>>>>>                 available boards. The Raspberry Pi is probably
>>>>>>>                 the most available board at $25 and $35 USD, and
>>>>>>>                 there have been over two million of these boards
>>>>>>>                 sold. The RTEMS head (4.11) currently has a
>>>>>>>                 basic BSP for the Raspberry Pi, supporting the
>>>>>>>                 CPU, a single UART, and timer. It is enough to
>>>>>>>                 run some basic RTEMS programs, but expanding the
>>>>>>>                 BSP to support peripherals will make it much
>>>>>>>                 more useful.
>>>>>>>                 For this project, the GSOC student could improve
>>>>>>>                 the peripheral support for the Raspberry Pi BSP.
>>>>>>>                 The peripherals we need to support (in order of
>>>>>>>                 increasing difficulty) include:
>>>>>>>                 1. GPIO (This has been done by one user, but is
>>>>>>>                 not integrated)
>>>>>>>                 2. I2C Bus
>>>>>>>                 3. SPI Bus
>>>>>>>                 4. Secure Digital card read and write support
>>>>>>>                 (using the SPI bus)
>>>>>>>                 5. Graphics / RTEMS Framebuffer Support (I have
>>>>>>>                 a graphics demo working in an RTEMS task)
>>>>>>>                 6. USB Device support
>>>>>>>                 7. HDMI/Graphics console (Requires framebuffer
>>>>>>>                 support and USB or GPIO connected keyboard device)
>>>>>>>                 8. Ethernet network support (Requires USB support)
>>>>>>>                 The entire list is probably too much for a
>>>>>>>                 single student to accomplish, so we can adjust
>>>>>>>                 the list of work according to what is possible.
>>>>>>>                 It may also be a good idea to add support for
>>>>>>>                 both models of the Raspberry Pi (256MB and
>>>>>>>                 512MB) and be able to configure the memory map
>>>>>>>                 in the BSP to match the boot time split between
>>>>>>>                 the CPU and GPU memory.
>>>>>>>                 Finally, in order to do some of this coding, it
>>>>>>>                 may be necessary to come up with a more
>>>>>>>                 efficient way to load and debug code on the
>>>>>>>                 Raspberry Pi. Options include using U-boot or
>>>>>>>                 connecting a JTAG debug device to load code.
>>>>>>>                 _______________________________________________
>>>>>>>                 rtems-users mailing list
>>>>>>>                 rtems-users at rtems.org  <mailto:rtems-users at rtems.org>
>>>>>>>                 http://www.rtems.org/mailman/listinfo/rtems-users
>>>>>                 Joel Sherrill, Ph.D.             Director of Research & Development
>>>>>                 joel.sherrill at OARcorp.com  <mailto:joel.sherrill at OARcorp.com>         On-Line Applications Research
>>>>>                 Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>                 Support Available(256) 722-9985  <tel:%28256%29%20722-9985>
URL: <http://lists.rtems.org/pipermail/users/attachments/20140319/4d081ccf/attachment-0001.html>
