potential GSOC project: Improve the Raspberry Pi BSP
    Gedare Bloom
    gedare at rtems.org
    Wed Mar 19 23:59:41 UTC 2014
On Wed, Mar 19, 2014 at 7:04 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 3/19/2014 4:18 PM, Pierre Ficheux wrote:
>> Hi Alan,
>> ----- Mail original -----
>>> De: "Alan Cudmore" <alan.cudmore at gmail.com>
>>> À: "Pierre Ficheux" <pierre.ficheux at openwide.fr>
>>> Cc: "Andre Marques" <andre.lousa.marques at gmail.com>, rtems-users at rtems.org
>>> Envoyé: Mercredi 19 Mars 2014 22:10:50
>>> Objet: Re: potential GSOC project: Improve the Raspberry Pi BSP
>>> Hi Pierre,
>>> We hope to use your GPIO implementation for this project. Any
>>> problems with incorporating it into the BSP?
>> No problem at all.
>>> For the USB and MMC support, the u-boot code would be nice, but it is
>>> GPL and not compatible with the RTEMS libraries. But it could serve
>>> as a reference.
>> I'm not aware of RTEMS licensing issue :) I know it's GPL with linking exception but what's the problem with "libraries" ?
> Ultimately, everything is statically linked together. So the license of
> a library
> could virally impact the license of all users.
> Ideally this support would be part of the BSP.
> There is a proposed API and simple driver model for analogs and discrete IO
> in RTEMS git in another git module. It includes some shell commands to
> assist
> in debugging and playing with IO settings.
Would adding "generic" RTEMS interfaces for GPIO, i2c, SPI, and SD
card with example implementations in Raspberry Pi be feasible and
interesting?
-Gedare
>>> Also, I am not sure how to approach the USB and network
>>> implementation. For example, we could probably get the Ethernet to
>>> work, and the USB code would just be "a bunch of files" in the
>>> ethernet driver directory. But I think the right way would be to use
>>> the FreeBSD library support of the USB and Ethernet devices. I just
>>> don't know how to do that :)
>> I do agree. I talked about U-Boot for MMC support though it includes USB support too.
> If this were in the new BSD USB/TCP/IP code, it should be
> straightforward to
> support both USB and TCP/IP.
>> regards
>>> Alan
>>> On Wed, Mar 19, 2014 at 4:33 PM, Pierre Ficheux <
>>> pierre.ficheux at openwide.fr > wrote:
>>> USB should be interesting too on RPi because of Ethernet support ;)
>>> Regarding SD card you should take a look at U-Boot for RPi which
>>> includes MMC support in drivers/mmc. U-Boot includes USB support for
>>> RPi too in drivers/usb.
>>> https://github.com/gonzoua/u-boot-pi
>>> regards
>>>> De: "Andre Marques" < andre.lousa.marques at gmail.com >
>>>> À: "Alan Cudmore" < alan.cudmore at gmail.com >
>>>> Cc: rtems-users at rtems.org
>>>> Envoyé: Mercredi 19 Mars 2014 20:59:56
>>>> Hello Alan,
>>>> I have decided to go with the framebuffer instead of the USB
>>>> support.
>>>> Will update the proposal with this.
>>>> Before GSOC I am considering to look at the SD card access through
>>>> the onboard card reader. What do you think?
>>>> --André Marques.
>>>> On 03/19/14 00:56, Alan Cudmore wrote:
>>>> Hi André ,
>>>> I agree about the USB stack. I am not even sure about how to
>>>> integrate a driver that depends on the FreeBSD USB stack.
>>>> The GPIO driver from Pierre is the one I was referring to. I don't
>>>> think anyone ever made a decision on how to integrate the GPIO
>>>> driver. If we have macros in the BSP header files then the GPIO can
>>>> be programmed with the simple macros or the driver that Pierre
>>>> wrote. If the project decides to use the GPIO device model for
>>>> other
>>>> BSPs, then the generic driver code can be moved to a shared
>>>> directory at a later date.
>>>> Thanks for the update,
>>>> Alan
>>>> On Tue, Mar 18, 2014 at 11:04 AM, Andre Marques <
>>>> andre.lousa.marques at gmail.com > wrote:
>>>> Hello,
>>>> about the USB driver port from FreeBSD I am finding it difficult to
>>>> gauge how much work it would involve, so I will follow your
>>>> suggestion and look at something else.
>>>> As for GPIO I belive the work that has been done is this:
>>>> https://github.com/pficheux/raspberry_pi/tree/master/RTEMS/gpio_driver
>>>> Am I right?
>>>> I also found a discussion on the best way of implementing the
>>>> driver
>>>> http://www.rtems.org/pipermail/rtems-users/2013-October/012059.html
>>>> but i am not sure if that came to a decision.
>>>> Meanwhile I will update the proposal with some basic info on the
>>>> drivers.
>>>> --André Marques.
>>>> On 03/14/14 13:16, Andre Marques wrote:
>>>> Hello,
>>>> On 03/14/14 02:33, Alan Cudmore wrote:
>>>> Andre,
>>>> I think your project proposal looks good, but I wonder if including
>>>> USB support is too much. There are low level "bare metal" USB
>>>> examples out there for the Raspberry Pi, and that may serve as a
>>>> starting point, but I think a real USB implementation will use the
>>>> BSD library that has been ported to RTEMS. It may be possible,
>>>> since
>>>> there is a FreeBSD port to the Raspberry Pi. Maybe others can help
>>>> here.
>>>> I will take a look into this.
>>>> If you think that GPIO, SPI, and I2C are not enough, then you could
>>>> always look at the framebuffer or SD card access.
>>>> Yes, right now I am trying to clarify everything the best I can so
>>>> I
>>>> don't end up with a lot more (or less) work than I can handle.
>>>> Finally, it may be necessary to have an Raspberry Pi and a few
>>>> peripherals. For example, I have an inexpensive I2C compass module
>>>> that I use with linux, and I have a breadboard wired up with LEDs
>>>> to
>>>> test GPIO.
>>>> Right now I have access to a Raspberry Pi at the university, not
>>>> sure
>>>> about the peripherals though. Anyway, if this projects really goes
>>>> forward I will get myself a raspberry and peripherals (I have
>>>> already some other components, like a breadboard, leds, wire, etc).
>>>> Thanks,
>>>> Alan
>>>> On Thu, Mar 13, 2014 at 8:32 PM, Alan Cudmore <
>>>> alan.cudmore at gmail.com > wrote:
>>>> I'm glad there is interest in this project. Andre, I will read your
>>>> proposal and provide feedback.
>>>> Joel, I was on the melange site and the system recognizes my
>>>> account.
>>>> Do I need to do anything to be a mentor for RTEMS?
>>>> Alan
>>>> On Thu, Mar 13, 2014 at 7:31 PM, Andre Marques <
>>>> It is now on melange too.
>>>> --André Marques.
>>>> On 03/13/14 23:21, Hesham Moustafa wrote:
>>>> Hi Andre,
>>>> I quote from RTEMS SoC page :
>>>> "GSOC STUDENTS! PLEASE FILL IN THE APPLICATION AT
>>>> http://www.google-melange.com ! YOU CAN EDIT UNTIL THE DEADLINE!
>>>> BUT
>>>> YOU WILL NOT GET A SLOT IF YOU DO NOT APPLY THROUGH Google!!!"
>>>> Regards,
>>>> Hesham
>>>> On Fri, Mar 14, 2014 at 1:16 AM, Andre Marques <
>>>> Hello,
>>>> I just posted the first proposal draft for "Raspberry Pi BSP
>>>> Peripherals " in the RTEMS Wiki
>>>> http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode
>>>> Any feedback is more than welcome. Should I post it already in
>>>> melange too?
>>>> --André Marques.
>>>> On 03/13/14 15:26, Joel Sherrill wrote:
>>>> On 3/13/2014 9:46 AM, Andre Marques wrote:
>>>> Hello,
>>>> I would be very interested in working in this project because I'm
>>>> currently trying to work with Raspberry Pi and RTEMS for my
>>>> undergraduate thesis, so this could be a great followup to that for
>>>> the summer.
>>>> I will need to do some reseach on it before making a proposal (the
>>>> time is also gettting shorter), but will post a proposal draft very
>>>> soon.
>>>> This would be a great area to work. As Alan says, the list is
>>>> likely
>>>> too much for
>>>> one student, so it seems likely that the work could be divided for
>>>> two students
>>>> working on different parts.
>>>> For the Pi Master list, I would like to add the Geert board. That
>>>> looks like something
>>>> of interest to RTEMS folks.
>>>> --joel
>>>> --André Marques.
>>>> On 03/13/14 11:23, Alan Cudmore wrote:
>>>> ( I posted this to the rtems-devel list by mistake, my apologies
>>>> for
>>>> the duplicate message )
>>>> f there are still potential GSOC students out there looking for a
>>>> project, I would like to offer a potential project to work on:
>>>> Improving the Raspberry Pi BSP. I would be happy to mentor a
>>>> student
>>>> for this project. Below is my description for the task.
>>>> Thanks,
>>>> Alan
>>>> One of the RTEMS Open Projects is to contribute a BSP or Board
>>>> Support Package for readily available boards. The Raspberry Pi is
>>>> probably the most available board at $25 and $35 USD, and there
>>>> have
>>>> been over two million of these boards sold. The RTEMS head (4.11)
>>>> currently has a basic BSP for the Raspberry Pi, supporting the CPU,
>>>> a single UART, and timer. It is enough to run some basic RTEMS
>>>> programs, but expanding the BSP to support peripherals will make it
>>>> much more useful.
>>>> For this project, the GSOC student could improve the peripheral
>>>> support for the Raspberry Pi BSP.
>>>> The peripherals we need to support (in order of increasing
>>>> difficulty) include:
>>>> 1. GPIO (This has been done by one user, but is not integrated)
>>>> 2. I2C Bus
>>>> 3. SPI Bus
>>>> 4. Secure Digital card read and write support (using the SPI bus)
>>>> 5. Graphics / RTEMS Framebuffer Support (I have a graphics demo
>>>> working in an RTEMS task)
>>>> 6. USB Device support
>>>> 7. HDMI/Graphics console (Requires framebuffer support and USB or
>>>> GPIO connected keyboard device)
>>>> 8. Ethernet network support (Requires USB support)
>>>> The entire list is probably too much for a single student to
>>>> accomplish, so we can adjust the list of work according to what is
>>>> possible.
>>>> It may also be a good idea to add support for both models of the
>>>> Raspberry Pi (256MB and 512MB) and be able to configure the memory
>>>> map in the BSP to match the boot time split between the CPU and GPU
>>>> memory.
>>>> Finally, in order to do some of this coding, it may be necessary to
>>>> come up with a more efficient way to load and debug code on the
>>>> Raspberry Pi. Options include using U-boot or connecting a JTAG
>>>> debug device to load code.
>>>> _______________________________________________
>>>> rtems-users mailing list rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
>>> Pierre FICHEUX -/- CTO OW/OWI, France -\- pierre.ficheux at openwide.fr
>>> http://ingenierie.openwide.fr
>>> http://www.linuxembedded.fr
>>> I would love to change the world, but they won't give me the source
>>> code
>> I would love to change the world, but they won't give me the source code
