potential GSOC project: Improve the Raspberry Pi BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Mar 20 00:00:27 UTC 2014
On 3/19/2014 6:59 PM, Gedare Bloom wrote:
> On Wed, Mar 19, 2014 at 7:04 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 3/19/2014 4:18 PM, Pierre Ficheux wrote:
>>> Hi Alan,
>>> ----- Mail original -----
>>>> De: "Alan Cudmore" <alan.cudmore at gmail.com>
>>>> À: "Pierre Ficheux" <pierre.ficheux at openwide.fr>
>>>> Cc: "Andre Marques" <andre.lousa.marques at gmail.com>, rtems-users at rtems.org
>>>> Envoyé: Mercredi 19 Mars 2014 22:10:50
>>>> Objet: Re: potential GSOC project: Improve the Raspberry Pi BSP
>>>> Hi Pierre,
>>>> We hope to use your GPIO implementation for this project. Any
>>>> problems with incorporating it into the BSP?
>>> No problem at all.
>>>> For the USB and MMC support, the u-boot code would be nice, but it is
>>>> GPL and not compatible with the RTEMS libraries. But it could serve
>>>> as a reference.
>>> I'm not aware of RTEMS licensing issue :) I know it's GPL with linking exception but what's the problem with "libraries" ?
>> Ultimately, everything is statically linked together. So the license of
>> a library
>> could virally impact the license of all users.
>> Ideally this support would be part of the BSP.
>> There is a proposed API and simple driver model for analogs and discrete IO
>> in RTEMS git in another git module. It includes some shell commands to
>> assist
>> in debugging and playing with IO settings.
> Would adding "generic" RTEMS interfaces for GPIO, i2c, SPI, and SD
> card with example implementations in Raspberry Pi be feasible and
> interesting?
TO me yes. To the student...?
> -Gedare
>>>> Also, I am not sure how to approach the USB and network
>>>> implementation. For example, we could probably get the Ethernet to
>>>> work, and the USB code would just be "a bunch of files" in the
>>>> ethernet driver directory. But I think the right way would be to use
>>>> the FreeBSD library support of the USB and Ethernet devices. I just
>>>> don't know how to do that :)
>>> I do agree. I talked about U-Boot for MMC support though it includes USB support too.
>> If this were in the new BSD USB/TCP/IP code, it should be
>> straightforward to
>> support both USB and TCP/IP.
>>> regards
>>>> Alan
>>>> On Wed, Mar 19, 2014 at 4:33 PM, Pierre Ficheux <
>>>> pierre.ficheux at openwide.fr > wrote:
>>>> USB should be interesting too on RPi because of Ethernet support ;)
>>>> Regarding SD card you should take a look at U-Boot for RPi which
>>>> includes MMC support in drivers/mmc. U-Boot includes USB support for
>>>> RPi too in drivers/usb.
>>>> https://github.com/gonzoua/u-boot-pi
>>>> regards
>>>>> De: "Andre Marques" < andre.lousa.marques at gmail.com >
>>>>> À: "Alan Cudmore" < alan.cudmore at gmail.com >
>>>>> Cc: rtems-users at rtems.org
>>>>> Envoyé: Mercredi 19 Mars 2014 20:59:56
>>>>> Hello Alan,
>>>>> I have decided to go with the framebuffer instead of the USB
>>>>> support.
>>>>> Will update the proposal with this.
>>>>> Before GSOC I am considering to look at the SD card access through
>>>>> the onboard card reader. What do you think?
>>>>> --André Marques.
>>>>> On 03/19/14 00:56, Alan Cudmore wrote:
>>>>> Hi André ,
>>>>> I agree about the USB stack. I am not even sure about how to
>>>>> integrate a driver that depends on the FreeBSD USB stack.
>>>>> The GPIO driver from Pierre is the one I was referring to. I don't
>>>>> think anyone ever made a decision on how to integrate the GPIO
>>>>> driver. If we have macros in the BSP header files then the GPIO can
>>>>> be programmed with the simple macros or the driver that Pierre
>>>>> wrote. If the project decides to use the GPIO device model for
>>>>> other
>>>>> BSPs, then the generic driver code can be moved to a shared
>>>>> directory at a later date.
>>>>> Thanks for the update,
>>>>> Alan
>>>>> On Tue, Mar 18, 2014 at 11:04 AM, Andre Marques <
>>>>> andre.lousa.marques at gmail.com > wrote:
>>>>> Hello,
>>>>> about the USB driver port from FreeBSD I am finding it difficult to
>>>>> gauge how much work it would involve, so I will follow your
>>>>> suggestion and look at something else.
>>>>> As for GPIO I belive the work that has been done is this:
>>>>> https://github.com/pficheux/raspberry_pi/tree/master/RTEMS/gpio_driver
>>>>> Am I right?
>>>>> I also found a discussion on the best way of implementing the
>>>>> driver
>>>>> http://www.rtems.org/pipermail/rtems-users/2013-October/012059.html
>>>>> but i am not sure if that came to a decision.
>>>>> Meanwhile I will update the proposal with some basic info on the
>>>>> drivers.
>>>>> --André Marques.
>>>>> On 03/14/14 13:16, Andre Marques wrote:
>>>>> Hello,
>>>>> On 03/14/14 02:33, Alan Cudmore wrote:
>>>>> Andre,
>>>>> I think your project proposal looks good, but I wonder if including
>>>>> USB support is too much. There are low level "bare metal" USB
>>>>> examples out there for the Raspberry Pi, and that may serve as a
>>>>> starting point, but I think a real USB implementation will use the
>>>>> BSD library that has been ported to RTEMS. It may be possible,
>>>>> since
>>>>> there is a FreeBSD port to the Raspberry Pi. Maybe others can help
>>>>> here.
>>>>> I will take a look into this.
>>>>> If you think that GPIO, SPI, and I2C are not enough, then you could
>>>>> always look at the framebuffer or SD card access.
>>>>> Yes, right now I am trying to clarify everything the best I can so
>>>>> I
>>>>> don't end up with a lot more (or less) work than I can handle.
>>>>> Finally, it may be necessary to have an Raspberry Pi and a few
>>>>> peripherals. For example, I have an inexpensive I2C compass module
>>>>> that I use with linux, and I have a breadboard wired up with LEDs
>>>>> to
>>>>> test GPIO.
>>>>> Right now I have access to a Raspberry Pi at the university, not
>>>>> sure
>>>>> about the peripherals though. Anyway, if this projects really goes
>>>>> forward I will get myself a raspberry and peripherals (I have
>>>>> already some other components, like a breadboard, leds, wire, etc).
>>>>> Thanks,
>>>>> Alan
>>>>> On Thu, Mar 13, 2014 at 8:32 PM, Alan Cudmore <
>>>>> alan.cudmore at gmail.com > wrote:
>>>>> I'm glad there is interest in this project. Andre, I will read your
>>>>> proposal and provide feedback.
>>>>> Joel, I was on the melange site and the system recognizes my
>>>>> account.
>>>>> Do I need to do anything to be a mentor for RTEMS?
>>>>> Alan
>>>>> On Thu, Mar 13, 2014 at 7:31 PM, Andre Marques <
>>>>> It is now on melange too.
>>>>> --André Marques.
>>>>> On 03/13/14 23:21, Hesham Moustafa wrote:
>>>>> Hi Andre,
>>>>> I quote from RTEMS SoC page :
>>>>> "GSOC STUDENTS! PLEASE FILL IN THE APPLICATION AT
>>>>> http://www.google-melange.com ! YOU CAN EDIT UNTIL THE DEADLINE!
>>>>> BUT
>>>>> YOU WILL NOT GET A SLOT IF YOU DO NOT APPLY THROUGH Google!!!"
>>>>> Regards,
>>>>> Hesham
>>>>> On Fri, Mar 14, 2014 at 1:16 AM, Andre Marques <
>>>>> Hello,
>>>>> I just posted the first proposal draft for "Raspberry Pi BSP
>>>>> Peripherals " in the RTEMS Wiki
>>>>> http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode
>>>>> Any feedback is more than welcome. Should I post it already in
>>>>> melange too?
>>>>> --André Marques.
>>>>> On 03/13/14 15:26, Joel Sherrill wrote:
>>>>> On 3/13/2014 9:46 AM, Andre Marques wrote:
>>>>> Hello,
>>>>> I would be very interested in working in this project because I'm
>>>>> currently trying to work with Raspberry Pi and RTEMS for my
>>>>> undergraduate thesis, so this could be a great followup to that for
>>>>> the summer.
>>>>> I will need to do some reseach on it before making a proposal (the
>>>>> time is also gettting shorter), but will post a proposal draft very
>>>>> soon.
>>>>> This would be a great area to work. As Alan says, the list is
>>>>> likely
>>>>> too much for
>>>>> one student, so it seems likely that the work could be divided for
>>>>> two students
>>>>> working on different parts.
>>>>> For the Pi Master list, I would like to add the Geert board. That
>>>>> looks like something
>>>>> of interest to RTEMS folks.
>>>>> --joel
>>>>> --André Marques.
>>>>> On 03/13/14 11:23, Alan Cudmore wrote:
>>>>> ( I posted this to the rtems-devel list by mistake, my apologies
>>>>> for
>>>>> the duplicate message )
>>>>> f there are still potential GSOC students out there looking for a
>>>>> project, I would like to offer a potential project to work on:
>>>>> Improving the Raspberry Pi BSP. I would be happy to mentor a
>>>>> student
>>>>> for this project. Below is my description for the task.
>>>>> Thanks,
>>>>> Alan
>>>>> One of the RTEMS Open Projects is to contribute a BSP or Board
>>>>> Support Package for readily available boards. The Raspberry Pi is
>>>>> probably the most available board at $25 and $35 USD, and there
>>>>> have
>>>>> been over two million of these boards sold. The RTEMS head (4.11)
>>>>> currently has a basic BSP for the Raspberry Pi, supporting the CPU,
>>>>> a single UART, and timer. It is enough to run some basic RTEMS
>>>>> programs, but expanding the BSP to support peripherals will make it
>>>>> much more useful.
>>>>> For this project, the GSOC student could improve the peripheral
>>>>> support for the Raspberry Pi BSP.
>>>>> The peripherals we need to support (in order of increasing
>>>>> difficulty) include:
>>>>> 1. GPIO (This has been done by one user, but is not integrated)
>>>>> 2. I2C Bus
>>>>> 3. SPI Bus
>>>>> 4. Secure Digital card read and write support (using the SPI bus)
>>>>> 5. Graphics / RTEMS Framebuffer Support (I have a graphics demo
>>>>> working in an RTEMS task)
>>>>> 6. USB Device support
>>>>> 7. HDMI/Graphics console (Requires framebuffer support and USB or
>>>>> GPIO connected keyboard device)
>>>>> 8. Ethernet network support (Requires USB support)
>>>>> The entire list is probably too much for a single student to
>>>>> accomplish, so we can adjust the list of work according to what is
>>>>> possible.
>>>>> It may also be a good idea to add support for both models of the
>>>>> Raspberry Pi (256MB and 512MB) and be able to configure the memory
>>>>> map in the BSP to match the boot time split between the CPU and GPU
>>>>> memory.
>>>>> Finally, in order to do some of this coding, it may be necessary to
>>>>> come up with a more efficient way to load and debug code on the
>>>>> Raspberry Pi. Options include using U-boot or connecting a JTAG
>>>>> debug device to load code.
>>>>> _______________________________________________
>>>>> rtems-users mailing list rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>> Support Available (256) 722-9985
>>>> Pierre FICHEUX -/- CTO OW/OWI, France -\- pierre.ficheux at openwide.fr
>>>> http://ingenierie.openwide.fr
>>>> http://www.linuxembedded.fr
>>>> I would love to change the world, but they won't give me the source
>>>> code
>>> I would love to change the world, but they won't give me the source code
