potential GSOC project: Improve the Raspberry Pi BSP
    Alan Cudmore
    alan.cudmore at gmail.com
    Fri Mar 21 00:45:45 UTC 2014
On 3/20/2014 7:54 PM, Andre Marques wrote:
> On 03/20/14 19:04, Joel Sherrill wrote:
>> On 3/20/2014 1:48 PM, Gedare Bloom wrote:
>>> On Thu, Mar 20, 2014 at 2:13 PM, Andre Marques
>>> <andre.lousa.marques at gmail.com> wrote:
>>>> On 03/20/14 13:58, Gedare Bloom wrote:
>>>>> Andre and Alan,
>>>>> I would be interested in seeing something like...
>>>>> rtems_spi_initialize(&spi_handle)
>>>>> rtems_spi_write(&spi_handle, data)
>>>>> rtems_spi_read(&spi_handle, &data)
>>>>> rtems_spi_ioctl(&spi_handle, &spi_control)
>>>>> or something similar, where spi can be replaced with i2c, gpio,
>>>>> 1-wire,
>>>>> etc.
>>>>> Something more generic might even work, like
>>>>> rtems_bus_initialize(BUS_TYPE_SPI, &bus_handle, ...)
>>>>> rtems_bus_write(&bus_handle, data)
>>>>> etc.
>>>>> This interface should "cover" the cpukit/libi2c,
>>>> cpukit/libi2c already provides those methods as rtems_libi2c_*, and
>>>> the type
>>>> of bus (i2c or spi) can be specified. The libi2c API separates the
>>>> low level
>>>> driver (board dependent) of the high level driver (device
>>>> dependent). In
>>>> this way every BSP only need to provide the low level driver, as
>>>> the device
>>>> drivers using the i2c or spi buses can be reused.
>>>> Not sure about what you meant with covering the libi2c.
>>> OK good it sounds like libi2c has much of the "generic" part taken
>>> care of.
>>>> GPIO seems to lack a generic interface in rtems, so I will think of
>>>> one.
>>> Good.
>> Please use this as a starting point for the API work.
>> http://git.rtems.org/multiio/
>> It includes driver code for two PC-104 multi IO cards, a start at a
>> driver/library abstraction interface, and shell commands get and
>> set analogs and discretes.
>> This code may be far from perfect from a "univeral RTEMS interface
>> view" but it is fielded. And we have one of the boards here in the
>> lab.
> It is getting late here (almost midnight) but I don't know if I have
> the time to do this planning in time for the proposal submition deadline.
> If you can review the current proposal see
> https://docs.google.com/document/d/13HiNH_EjnzbA3HJ86Cmd2Ooi0YOsehSGkTILD_M-REw
I think this proposal looks good. It is clear and detailed. Since time
is short, we can talk about common driver interfaces during the project.
Thanks,
Alan
>>> -Gedare
>>>>>    and be implemented in
>>>>> RPi as an example. then, any BSP that implements this interface can
>>>>> support the applications that use it.
>>>>> -Gedare
>>>>> On Thu, Mar 20, 2014 at 5:36 AM, Andre Marques
>>>>>> On 03/20/14 02:21, Alan Cudmore wrote:
>>>>>> Interesting idea.
>>>>>> Part of this may be done:
>>>>>> GPIO : Can start with Pierre's implementation
>>>>>> i2c: Isn't there a libi2c already?
>>>>>> SPI: ?
>>>>>> cpukit/libi2c also deals with SPI.
>>>>>> It is also implemented on the FreeBSD port to RPi
>>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/broadcom/bcm2835/bcm2835_spi.c
>>>>>> and more info can be found at
>>>>>> http://elinux.org/RPi_SPI
>>>>>> SD card: ? There should be at least one example to follow in the ARM
>>>>>> tree.
>>>>>> Framebuffer: I think this is well defined.
>>>>>> Alan
>>>>>> On Wed, Mar 19, 2014 at 7:59 PM, Gedare Bloom <gedare at rtems.org>
>>>>>> wrote:
>>>>>>> On Wed, Mar 19, 2014 at 7:04 PM, Joel Sherrill
>>>>>>> <joel.sherrill at oarcorp.com> wrote:
>>>>>>>> On 3/19/2014 4:18 PM, Pierre Ficheux wrote:
>>>>>>>>> Hi Alan,
>>>>>>>>> ----- Mail original -----
>>>>>>>>>> De: "Alan Cudmore" <alan.cudmore at gmail.com>
>>>>>>>>>> À: "Pierre Ficheux" <pierre.ficheux at openwide.fr>
>>>>>>>>>> Cc: "Andre Marques" <andre.lousa.marques at gmail.com>,
>>>>>>>>>> rtems-users at rtems.org
>>>>>>>>>> Envoyé: Mercredi 19 Mars 2014 22:10:50
>>>>>>>>>> Objet: Re: potential GSOC project: Improve the Raspberry Pi BSP
>>>>>>>>>> Hi Pierre,
>>>>>>>>>> We hope to use your GPIO implementation for this project. Any
>>>>>>>>>> problems with incorporating it into the BSP?
>>>>>>>>> No problem at all.
>>>>>>>>>> For the USB and MMC support, the u-boot code would be nice,
>>>>>>>>>> but it is
>>>>>>>>>> GPL and not compatible with the RTEMS libraries. But it could
>>>>>>>>>> serve
>>>>>>>>>> as a reference.
>>>>>>>>> I'm not aware of RTEMS licensing issue :) I know it's GPL with
>>>>>>>>> linking
>>>>>>>>> exception but what's the problem with "libraries" ?
>>>>>>>> Ultimately, everything is statically linked together. So the
>>>>>>>> license of
>>>>>>>> a library
>>>>>>>> could virally impact the license of all users.
>>>>>>>> Ideally this support would be part of the BSP.
>>>>>>>> There is a proposed API and simple driver model for analogs and
>>>>>>>> discrete
>>>>>>>> IO
>>>>>>>> in RTEMS git in another git module. It includes some shell
>>>>>>>> commands to
>>>>>>>> assist
>>>>>>>> in debugging and playing with IO settings.
>>>>>>> Would adding "generic" RTEMS interfaces for GPIO, i2c, SPI, and SD
>>>>>>> card with example implementations in Raspberry Pi be feasible and
>>>>>>> interesting?
>>>>>>> -Gedare
>>>>>>>>>> Also, I am not sure how to approach the USB and network
>>>>>>>>>> implementation. For example, we could probably get the
>>>>>>>>>> Ethernet to
>>>>>>>>>> work, and the USB code would just be "a bunch of files" in the
>>>>>>>>>> ethernet driver directory. But I think the right way would be
>>>>>>>>>> to use
>>>>>>>>>> the FreeBSD library support of the USB and Ethernet devices.
>>>>>>>>>> I just
>>>>>>>>>> don't know how to do that :)
>>>>>>>>> I do agree. I talked about U-Boot for MMC support though it
>>>>>>>>> includes
>>>>>>>>> USB support too.
>>>>>>>> If this were in the new BSD USB/TCP/IP code, it should be
>>>>>>>> straightforward to
>>>>>>>> support both USB and TCP/IP.
>>>>>>>>> regards
>>>>>>>>>> Alan
>>>>>>>>>> On Wed, Mar 19, 2014 at 4:33 PM, Pierre Ficheux <
>>>>>>>>>> pierre.ficheux at openwide.fr > wrote:
>>>>>>>>>> USB should be interesting too on RPi because of Ethernet
>>>>>>>>>> support ;)
>>>>>>>>>> Regarding SD card you should take a look at U-Boot for RPi which
>>>>>>>>>> includes MMC support in drivers/mmc. U-Boot includes USB
>>>>>>>>>> support for
>>>>>>>>>> RPi too in drivers/usb.
>>>>>>>>>> https://github.com/gonzoua/u-boot-pi
>>>>>>>>>> regards
>>>>>>>>>>> De: "Andre Marques" < andre.lousa.marques at gmail.com >
>>>>>>>>>>> À: "Alan Cudmore" < alan.cudmore at gmail.com >
>>>>>>>>>>> Cc: rtems-users at rtems.org
>>>>>>>>>>> Envoyé: Mercredi 19 Mars 2014 20:59:56
>>>>>>>>>>> Hello Alan,
>>>>>>>>>>> I have decided to go with the framebuffer instead of the USB
>>>>>>>>>>> support.
>>>>>>>>>>> Will update the proposal with this.
>>>>>>>>>>> Before GSOC I am considering to look at the SD card access
>>>>>>>>>>> through
>>>>>>>>>>> the onboard card reader. What do you think?
>>>>>>>>>>> --André Marques.
>>>>>>>>>>> On 03/19/14 00:56, Alan Cudmore wrote:
>>>>>>>>>>> Hi André ,
>>>>>>>>>>> I agree about the USB stack. I am not even sure about how to
>>>>>>>>>>> integrate a driver that depends on the FreeBSD USB stack.
>>>>>>>>>>> The GPIO driver from Pierre is the one I was referring to. I
>>>>>>>>>>> don't
>>>>>>>>>>> think anyone ever made a decision on how to integrate the GPIO
>>>>>>>>>>> driver. If we have macros in the BSP header files then the
>>>>>>>>>>> GPIO can
>>>>>>>>>>> be programmed with the simple macros or the driver that Pierre
>>>>>>>>>>> wrote. If the project decides to use the GPIO device model for
>>>>>>>>>>> other
>>>>>>>>>>> BSPs, then the generic driver code can be moved to a shared
>>>>>>>>>>> directory at a later date.
>>>>>>>>>>> Thanks for the update,
>>>>>>>>>>> Alan
>>>>>>>>>>> On Tue, Mar 18, 2014 at 11:04 AM, Andre Marques <
>>>>>>>>>>> andre.lousa.marques at gmail.com > wrote:
>>>>>>>>>>> Hello,
>>>>>>>>>>> about the USB driver port from FreeBSD I am finding it
>>>>>>>>>>> difficult to
>>>>>>>>>>> gauge how much work it would involve, so I will follow your
>>>>>>>>>>> suggestion and look at something else.
>>>>>>>>>>> As for GPIO I belive the work that has been done is this:
>>>>>>>>>>> https://github.com/pficheux/raspberry_pi/tree/master/RTEMS/gpio_driver
>>>>>>>>>>> Am I right?
>>>>>>>>>>> I also found a discussion on the best way of implementing the
>>>>>>>>>>> driver
>>>>>>>>>>> http://www.rtems.org/pipermail/rtems-users/2013-October/012059.html
>>>>>>>>>>> but i am not sure if that came to a decision.
>>>>>>>>>>> Meanwhile I will update the proposal with some basic info on
>>>>>>>>>>> the
>>>>>>>>>>> drivers.
>>>>>>>>>>> --André Marques.
>>>>>>>>>>> On 03/14/14 13:16, Andre Marques wrote:
>>>>>>>>>>> Hello,
>>>>>>>>>>> On 03/14/14 02:33, Alan Cudmore wrote:
>>>>>>>>>>> Andre,
>>>>>>>>>>> I think your project proposal looks good, but I wonder if
>>>>>>>>>>> including
>>>>>>>>>>> USB support is too much. There are low level "bare metal" USB
>>>>>>>>>>> examples out there for the Raspberry Pi, and that may serve
>>>>>>>>>>> as a
>>>>>>>>>>> starting point, but I think a real USB implementation will
>>>>>>>>>>> use the
>>>>>>>>>>> BSD library that has been ported to RTEMS. It may be possible,
>>>>>>>>>>> since
>>>>>>>>>>> there is a FreeBSD port to the Raspberry Pi. Maybe others
>>>>>>>>>>> can help
>>>>>>>>>>> here.
>>>>>>>>>>> I will take a look into this.
>>>>>>>>>>> If you think that GPIO, SPI, and I2C are not enough, then
>>>>>>>>>>> you could
>>>>>>>>>>> always look at the framebuffer or SD card access.
>>>>>>>>>>> Yes, right now I am trying to clarify everything the best I
>>>>>>>>>>> can so
>>>>>>>>>>> I
>>>>>>>>>>> don't end up with a lot more (or less) work than I can handle.
>>>>>>>>>>> Finally, it may be necessary to have an Raspberry Pi and a few
>>>>>>>>>>> peripherals. For example, I have an inexpensive I2C compass
>>>>>>>>>>> module
>>>>>>>>>>> that I use with linux, and I have a breadboard wired up with
>>>>>>>>>>> LEDs
>>>>>>>>>>> to
>>>>>>>>>>> test GPIO.
>>>>>>>>>>> Right now I have access to a Raspberry Pi at the university,
>>>>>>>>>>> not
>>>>>>>>>>> sure
>>>>>>>>>>> about the peripherals though. Anyway, if this projects
>>>>>>>>>>> really goes
>>>>>>>>>>> forward I will get myself a raspberry and peripherals (I have
>>>>>>>>>>> already some other components, like a breadboard, leds,
>>>>>>>>>>> wire, etc).
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Alan
>>>>>>>>>>> On Thu, Mar 13, 2014 at 8:32 PM, Alan Cudmore <
>>>>>>>>>>> alan.cudmore at gmail.com > wrote:
>>>>>>>>>>> I'm glad there is interest in this project. Andre, I will
>>>>>>>>>>> read your
>>>>>>>>>>> proposal and provide feedback.
>>>>>>>>>>> Joel, I was on the melange site and the system recognizes my
>>>>>>>>>>> account.
>>>>>>>>>>> Do I need to do anything to be a mentor for RTEMS?
>>>>>>>>>>> Alan
>>>>>>>>>>> On Thu, Mar 13, 2014 at 7:31 PM, Andre Marques <
>>>>>>>>>>> It is now on melange too.
>>>>>>>>>>> --André Marques.
>>>>>>>>>>> On 03/13/14 23:21, Hesham Moustafa wrote:
>>>>>>>>>>> Hi Andre,
>>>>>>>>>>> I quote from RTEMS SoC page :
>>>>>>>>>>> "GSOC STUDENTS! PLEASE FILL IN THE APPLICATION AT
>>>>>>>>>>> http://www.google-melange.com ! YOU CAN EDIT UNTIL THE
>>>>>>>>>>> DEADLINE!
>>>>>>>>>>> BUT
>>>>>>>>>>> YOU WILL NOT GET A SLOT IF YOU DO NOT APPLY THROUGH Google!!!"
>>>>>>>>>>> Regards,
>>>>>>>>>>> Hesham
>>>>>>>>>>> On Fri, Mar 14, 2014 at 1:16 AM, Andre Marques <
>>>>>>>>>>> Hello,
>>>>>>>>>>> I just posted the first proposal draft for "Raspberry Pi BSP
>>>>>>>>>>> Peripherals " in the RTEMS Wiki
>>>>>>>>>>> http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode
>>>>>>>>>>> Any feedback is more than welcome. Should I post it already in
>>>>>>>>>>> melange too?
>>>>>>>>>>> --André Marques.
>>>>>>>>>>> On 03/13/14 15:26, Joel Sherrill wrote:
>>>>>>>>>>> On 3/13/2014 9:46 AM, Andre Marques wrote:
>>>>>>>>>>> Hello,
>>>>>>>>>>> I would be very interested in working in this project
>>>>>>>>>>> because I'm
>>>>>>>>>>> currently trying to work with Raspberry Pi and RTEMS for my
>>>>>>>>>>> undergraduate thesis, so this could be a great followup to
>>>>>>>>>>> that for
>>>>>>>>>>> the summer.
>>>>>>>>>>> I will need to do some reseach on it before making a
>>>>>>>>>>> proposal (the
>>>>>>>>>>> time is also gettting shorter), but will post a proposal
>>>>>>>>>>> draft very
>>>>>>>>>>> soon.
>>>>>>>>>>> This would be a great area to work. As Alan says, the list is
>>>>>>>>>>> likely
>>>>>>>>>>> too much for
>>>>>>>>>>> one student, so it seems likely that the work could be
>>>>>>>>>>> divided for
>>>>>>>>>>> two students
>>>>>>>>>>> working on different parts.
>>>>>>>>>>> For the Pi Master list, I would like to add the Geert board.
>>>>>>>>>>> That
>>>>>>>>>>> looks like something
>>>>>>>>>>> of interest to RTEMS folks.
>>>>>>>>>>> --joel
>>>>>>>>>>> --André Marques.
>>>>>>>>>>> On 03/13/14 11:23, Alan Cudmore wrote:
>>>>>>>>>>> ( I posted this to the rtems-devel list by mistake, my
>>>>>>>>>>> apologies
>>>>>>>>>>> for
>>>>>>>>>>> the duplicate message )
>>>>>>>>>>> f there are still potential GSOC students out there looking
>>>>>>>>>>> for a
>>>>>>>>>>> project, I would like to offer a potential project to work on:
>>>>>>>>>>> Improving the Raspberry Pi BSP. I would be happy to mentor a
>>>>>>>>>>> student
>>>>>>>>>>> for this project. Below is my description for the task.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Alan
>>>>>>>>>>> One of the RTEMS Open Projects is to contribute a BSP or Board
>>>>>>>>>>> Support Package for readily available boards. The Raspberry
>>>>>>>>>>> Pi is
>>>>>>>>>>> probably the most available board at $25 and $35 USD, and there
>>>>>>>>>>> have
>>>>>>>>>>> been over two million of these boards sold. The RTEMS head
>>>>>>>>>>> (4.11)
>>>>>>>>>>> currently has a basic BSP for the Raspberry Pi, supporting
>>>>>>>>>>> the CPU,
>>>>>>>>>>> a single UART, and timer. It is enough to run some basic RTEMS
>>>>>>>>>>> programs, but expanding the BSP to support peripherals will
>>>>>>>>>>> make it
>>>>>>>>>>> much more useful.
>>>>>>>>>>> For this project, the GSOC student could improve the peripheral
>>>>>>>>>>> support for the Raspberry Pi BSP.
>>>>>>>>>>> The peripherals we need to support (in order of increasing
>>>>>>>>>>> difficulty) include:
>>>>>>>>>>> 1. GPIO (This has been done by one user, but is not integrated)
>>>>>>>>>>> 2. I2C Bus
>>>>>>>>>>> 3. SPI Bus
>>>>>>>>>>> 4. Secure Digital card read and write support (using the SPI
>>>>>>>>>>> bus)
>>>>>>>>>>> 5. Graphics / RTEMS Framebuffer Support (I have a graphics demo
>>>>>>>>>>> working in an RTEMS task)
>>>>>>>>>>> 6. USB Device support
>>>>>>>>>>> 7. HDMI/Graphics console (Requires framebuffer support and
>>>>>>>>>>> USB or
>>>>>>>>>>> GPIO connected keyboard device)
>>>>>>>>>>> 8. Ethernet network support (Requires USB support)
>>>>>>>>>>> The entire list is probably too much for a single student to
>>>>>>>>>>> accomplish, so we can adjust the list of work according to
>>>>>>>>>>> what is
>>>>>>>>>>> possible.
>>>>>>>>>>> It may also be a good idea to add support for both models of
>>>>>>>>>>> the
>>>>>>>>>>> Raspberry Pi (256MB and 512MB) and be able to configure the
>>>>>>>>>>> memory
>>>>>>>>>>> map in the BSP to match the boot time split between the CPU
>>>>>>>>>>> and GPU
>>>>>>>>>>> memory.
>>>>>>>>>>> Finally, in order to do some of this coding, it may be
>>>>>>>>>>> necessary to
>>>>>>>>>>> come up with a more efficient way to load and debug code on the
>>>>>>>>>>> Raspberry Pi. Options include using U-boot or connecting a JTAG
>>>>>>>>>>> debug device to load code.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> rtems-users mailing list rtems-users at rtems.org
>>>>>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>>>>>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>>>>>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>>>>>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>>>>>>>> Support Available (256) 722-9985
>>>>>>>>>> Pierre FICHEUX -/- CTO OW/OWI, France -\-
>>>>>>>>>> http://ingenierie.openwide.fr
>>>>>>>>>> http://www.linuxembedded.fr
>>>>>>>>>> I would love to change the world, but they won't give me the
>>>>>>>>>> source
>>>>>>>>>> code
>>>>>>>>> source
>>>>>>>>> code
>>>>>>>> Development
