potential GSOC project: Improve the Raspberry Pi BSP
Pierre Ficheux
pierre.ficheux at openwide.fr
Fri Mar 21 11:26:21 UTC 2014
I do agree. Looks fine.
----- Mail original -----
> De: "Alan Cudmore" <alan.cudmore at gmail.com>
> À: "Andre Marques" <andre.lousa.marques at gmail.com>, "Joel Sherrill" <joel.sherrill at oarcorp.com>
> Cc: rtems-users at rtems.org
> Envoyé: Vendredi 21 Mars 2014 01:45:45
> Objet: Re: potential GSOC project: Improve the Raspberry Pi BSP
> On 3/20/2014 7:54 PM, Andre Marques wrote:
> > On 03/20/14 19:04, Joel Sherrill wrote:
> >> On 3/20/2014 1:48 PM, Gedare Bloom wrote:
> >>> On Thu, Mar 20, 2014 at 2:13 PM, Andre Marques
> >>> <andre.lousa.marques at gmail.com> wrote:
> >>>> On 03/20/14 13:58, Gedare Bloom wrote:
> >>>>> Andre and Alan,
> >>>>> I would be interested in seeing something like...
> >>>>> rtems_spi_initialize(&spi_handle)
> >>>>> rtems_spi_write(&spi_handle, data)
> >>>>> rtems_spi_read(&spi_handle, &data)
> >>>>> rtems_spi_ioctl(&spi_handle, &spi_control)
> >>>>> or something similar, where spi can be replaced with i2c, gpio,
> >>>>> 1-wire,
> >>>>> etc.
> >>>>> Something more generic might even work, like
> >>>>> rtems_bus_initialize(BUS_TYPE_SPI, &bus_handle, ...)
> >>>>> rtems_bus_write(&bus_handle, data)
> >>>>> etc.
> >>>>> This interface should "cover" the cpukit/libi2c,
> >>>> cpukit/libi2c already provides those methods as rtems_libi2c_*,
> >>>> and
> >>>> the type
> >>>> of bus (i2c or spi) can be specified. The libi2c API separates
> >>>> the
> >>>> low level
> >>>> driver (board dependent) of the high level driver (device
> >>>> dependent). In
> >>>> this way every BSP only need to provide the low level driver, as
> >>>> the device
> >>>> drivers using the i2c or spi buses can be reused.
> >>>> Not sure about what you meant with covering the libi2c.
> >>> OK good it sounds like libi2c has much of the "generic" part
> >>> taken
> >>> care of.
> >>>> GPIO seems to lack a generic interface in rtems, so I will think
> >>>> of
> >>>> one.
> >>> Good.
> >> Please use this as a starting point for the API work.
> >> http://git.rtems.org/multiio/
> >> It includes driver code for two PC-104 multi IO cards, a start at
> >> a
> >> driver/library abstraction interface, and shell commands get and
> >> set analogs and discretes.
> >> This code may be far from perfect from a "univeral RTEMS interface
> >> view" but it is fielded. And we have one of the boards here in the
> >> lab.
> > It is getting late here (almost midnight) but I don't know if I
> > have
> > the time to do this planning in time for the proposal submition
> > deadline.
> > If you can review the current proposal see
> > https://docs.google.com/document/d/13HiNH_EjnzbA3HJ86Cmd2Ooi0YOsehSGkTILD_M-REw
> I think this proposal looks good. It is clear and detailed. Since
> time
> is short, we can talk about common driver interfaces during the
> project.
> Thanks,
> Alan
> >>> -Gedare
> >>>>> and be implemented in
> >>>>> RPi as an example. then, any BSP that implements this interface
> >>>>> can
> >>>>> support the applications that use it.
> >>>>> -Gedare
> >>>>> On Thu, Mar 20, 2014 at 5:36 AM, Andre Marques
> >>>>>> On 03/20/14 02:21, Alan Cudmore wrote:
> >>>>>> Interesting idea.
> >>>>>> Part of this may be done:
> >>>>>> GPIO : Can start with Pierre's implementation
> >>>>>> i2c: Isn't there a libi2c already?
> >>>>>> SPI: ?
> >>>>>> cpukit/libi2c also deals with SPI.
> >>>>>> It is also implemented on the FreeBSD port to RPi
> >>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/broadcom/bcm2835/bcm2835_spi.c
> >>>>>> and more info can be found at
> >>>>>> http://elinux.org/RPi_SPI
> >>>>>> SD card: ? There should be at least one example to follow in
> >>>>>> the ARM
> >>>>>> tree.
> >>>>>> Framebuffer: I think this is well defined.
> >>>>>> Alan
> >>>>>> On Wed, Mar 19, 2014 at 7:59 PM, Gedare Bloom
> >>>>>> <gedare at rtems.org>
> >>>>>> wrote:
> >>>>>>> On Wed, Mar 19, 2014 at 7:04 PM, Joel Sherrill
> >>>>>>> <joel.sherrill at oarcorp.com> wrote:
> >>>>>>>> On 3/19/2014 4:18 PM, Pierre Ficheux wrote:
> >>>>>>>>> Hi Alan,
> >>>>>>>>>> À: "Pierre Ficheux" <pierre.ficheux at openwide.fr>
> >>>>>>>>>> Cc: "Andre Marques" <andre.lousa.marques at gmail.com>,
> >>>>>>>>>> Envoyé: Mercredi 19 Mars 2014 22:10:50
> >>>>>>>>>> Pi BSP
> >>>>>>>>>> Hi Pierre,
> >>>>>>>>>> We hope to use your GPIO implementation for this project.
> >>>>>>>>>> Any
> >>>>>>>>>> problems with incorporating it into the BSP?
> >>>>>>>>> No problem at all.
> >>>>>>>>>> For the USB and MMC support, the u-boot code would be
> >>>>>>>>>> nice,
> >>>>>>>>>> but it is
> >>>>>>>>>> GPL and not compatible with the RTEMS libraries. But it
> >>>>>>>>>> could
> >>>>>>>>>> serve
> >>>>>>>>>> as a reference.
> >>>>>>>>> I'm not aware of RTEMS licensing issue :) I know it's GPL
> >>>>>>>>> with
> >>>>>>>>> linking
> >>>>>>>>> exception but what's the problem with "libraries" ?
> >>>>>>>> Ultimately, everything is statically linked together. So the
> >>>>>>>> license of
> >>>>>>>> a library
> >>>>>>>> could virally impact the license of all users.
> >>>>>>>> Ideally this support would be part of the BSP.
> >>>>>>>> There is a proposed API and simple driver model for analogs
> >>>>>>>> and
> >>>>>>>> discrete
> >>>>>>>> IO
> >>>>>>>> in RTEMS git in another git module. It includes some shell
> >>>>>>>> commands to
> >>>>>>>> assist
> >>>>>>>> in debugging and playing with IO settings.
> >>>>>>> Would adding "generic" RTEMS interfaces for GPIO, i2c, SPI,
> >>>>>>> and SD
> >>>>>>> card with example implementations in Raspberry Pi be feasible
> >>>>>>> and
> >>>>>>> interesting?
> >>>>>>> -Gedare
> >>>>>>>>>> Also, I am not sure how to approach the USB and network
> >>>>>>>>>> implementation. For example, we could probably get the
> >>>>>>>>>> Ethernet to
> >>>>>>>>>> work, and the USB code would just be "a bunch of files" in
> >>>>>>>>>> the
> >>>>>>>>>> ethernet driver directory. But I think the right way would
> >>>>>>>>>> be
> >>>>>>>>>> to use
> >>>>>>>>>> the FreeBSD library support of the USB and Ethernet
> >>>>>>>>>> devices.
> >>>>>>>>>> I just
> >>>>>>>>>> don't know how to do that :)
> >>>>>>>>> I do agree. I talked about U-Boot for MMC support though it
> >>>>>>>>> includes
> >>>>>>>>> USB support too.
> >>>>>>>> If this were in the new BSD USB/TCP/IP code, it should be
> >>>>>>>> straightforward to
> >>>>>>>> support both USB and TCP/IP.
> >>>>>>>>> regards
> >>>>>>>>>> Alan
> >>>>>>>>>> On Wed, Mar 19, 2014 at 4:33 PM, Pierre Ficheux <
> >>>>>>>>>> pierre.ficheux at openwide.fr > wrote:
> >>>>>>>>>> USB should be interesting too on RPi because of Ethernet
> >>>>>>>>>> support ;)
> >>>>>>>>>> Regarding SD card you should take a look at U-Boot for RPi
> >>>>>>>>>> which
> >>>>>>>>>> includes MMC support in drivers/mmc. U-Boot includes USB
> >>>>>>>>>> support for
> >>>>>>>>>> RPi too in drivers/usb.
> >>>>>>>>>> https://github.com/gonzoua/u-boot-pi
> >>>>>>>>>> regards
> >>>>>>>>>>> De: "Andre Marques" < andre.lousa.marques at gmail.com >
> >>>>>>>>>>> À: "Alan Cudmore" < alan.cudmore at gmail.com >
> >>>>>>>>>>> Envoyé: Mercredi 19 Mars 2014 20:59:56
> >>>>>>>>>>> Pi BSP
> >>>>>>>>>>> Hello Alan,
> >>>>>>>>>>> I have decided to go with the framebuffer instead of the
> >>>>>>>>>>> USB
> >>>>>>>>>>> support.
> >>>>>>>>>>> Will update the proposal with this.
> >>>>>>>>>>> Before GSOC I am considering to look at the SD card
> >>>>>>>>>>> access
> >>>>>>>>>>> through
> >>>>>>>>>>> the onboard card reader. What do you think?
> >>>>>>>>>>> --André Marques.
> >>>>>>>>>>> On 03/19/14 00:56, Alan Cudmore wrote:
> >>>>>>>>>>> Hi André ,
> >>>>>>>>>>> I agree about the USB stack. I am not even sure about how
> >>>>>>>>>>> to
> >>>>>>>>>>> integrate a driver that depends on the FreeBSD USB stack.
> >>>>>>>>>>> The GPIO driver from Pierre is the one I was referring
> >>>>>>>>>>> to. I
> >>>>>>>>>>> don't
> >>>>>>>>>>> think anyone ever made a decision on how to integrate the
> >>>>>>>>>>> GPIO
> >>>>>>>>>>> driver. If we have macros in the BSP header files then
> >>>>>>>>>>> the
> >>>>>>>>>>> GPIO can
> >>>>>>>>>>> be programmed with the simple macros or the driver that
> >>>>>>>>>>> Pierre
> >>>>>>>>>>> wrote. If the project decides to use the GPIO device
> >>>>>>>>>>> model for
> >>>>>>>>>>> other
> >>>>>>>>>>> BSPs, then the generic driver code can be moved to a
> >>>>>>>>>>> shared
> >>>>>>>>>>> directory at a later date.
> >>>>>>>>>>> Thanks for the update,
> >>>>>>>>>>> Alan
> >>>>>>>>>>> On Tue, Mar 18, 2014 at 11:04 AM, Andre Marques <
> >>>>>>>>>>> andre.lousa.marques at gmail.com > wrote:
> >>>>>>>>>>> Hello,
> >>>>>>>>>>> about the USB driver port from FreeBSD I am finding it
> >>>>>>>>>>> difficult to
> >>>>>>>>>>> gauge how much work it would involve, so I will follow
> >>>>>>>>>>> your
> >>>>>>>>>>> suggestion and look at something else.
> >>>>>>>>>>> As for GPIO I belive the work that has been done is this:
> >>>>>>>>>>> https://github.com/pficheux/raspberry_pi/tree/master/RTEMS/gpio_driver
> >>>>>>>>>>> Am I right?
> >>>>>>>>>>> I also found a discussion on the best way of implementing
> >>>>>>>>>>> the
> >>>>>>>>>>> driver
> >>>>>>>>>>> http://www.rtems.org/pipermail/rtems-users/2013-October/012059.html
> >>>>>>>>>>> but i am not sure if that came to a decision.
> >>>>>>>>>>> Meanwhile I will update the proposal with some basic info
> >>>>>>>>>>> on
> >>>>>>>>>>> the
> >>>>>>>>>>> drivers.
> >>>>>>>>>>> --André Marques.
> >>>>>>>>>>> On 03/14/14 13:16, Andre Marques wrote:
> >>>>>>>>>>> Hello,
> >>>>>>>>>>> On 03/14/14 02:33, Alan Cudmore wrote:
> >>>>>>>>>>> Andre,
> >>>>>>>>>>> I think your project proposal looks good, but I wonder if
> >>>>>>>>>>> including
> >>>>>>>>>>> USB support is too much. There are low level "bare metal"
> >>>>>>>>>>> USB
> >>>>>>>>>>> examples out there for the Raspberry Pi, and that may
> >>>>>>>>>>> serve
> >>>>>>>>>>> as a
> >>>>>>>>>>> starting point, but I think a real USB implementation
> >>>>>>>>>>> will
> >>>>>>>>>>> use the
> >>>>>>>>>>> BSD library that has been ported to RTEMS. It may be
> >>>>>>>>>>> possible,
> >>>>>>>>>>> since
> >>>>>>>>>>> there is a FreeBSD port to the Raspberry Pi. Maybe others
> >>>>>>>>>>> can help
> >>>>>>>>>>> here.
> >>>>>>>>>>> I will take a look into this.
> >>>>>>>>>>> If you think that GPIO, SPI, and I2C are not enough, then
> >>>>>>>>>>> you could
> >>>>>>>>>>> always look at the framebuffer or SD card access.
> >>>>>>>>>>> Yes, right now I am trying to clarify everything the best
> >>>>>>>>>>> I
> >>>>>>>>>>> can so
> >>>>>>>>>>> I
> >>>>>>>>>>> don't end up with a lot more (or less) work than I can
> >>>>>>>>>>> handle.
> >>>>>>>>>>> Finally, it may be necessary to have an Raspberry Pi and
> >>>>>>>>>>> a few
> >>>>>>>>>>> peripherals. For example, I have an inexpensive I2C
> >>>>>>>>>>> compass
> >>>>>>>>>>> module
> >>>>>>>>>>> that I use with linux, and I have a breadboard wired up
> >>>>>>>>>>> with
> >>>>>>>>>>> LEDs
> >>>>>>>>>>> to
> >>>>>>>>>>> test GPIO.
> >>>>>>>>>>> Right now I have access to a Raspberry Pi at the
> >>>>>>>>>>> university,
> >>>>>>>>>>> not
> >>>>>>>>>>> sure
> >>>>>>>>>>> about the peripherals though. Anyway, if this projects
> >>>>>>>>>>> really goes
> >>>>>>>>>>> forward I will get myself a raspberry and peripherals (I
> >>>>>>>>>>> have
> >>>>>>>>>>> already some other components, like a breadboard, leds,
> >>>>>>>>>>> wire, etc).
> >>>>>>>>>>> Thanks,
> >>>>>>>>>>> Alan
> >>>>>>>>>>> On Thu, Mar 13, 2014 at 8:32 PM, Alan Cudmore <
> >>>>>>>>>>> alan.cudmore at gmail.com > wrote:
> >>>>>>>>>>> I'm glad there is interest in this project. Andre, I will
> >>>>>>>>>>> read your
> >>>>>>>>>>> proposal and provide feedback.
> >>>>>>>>>>> Joel, I was on the melange site and the system recognizes
> >>>>>>>>>>> my
> >>>>>>>>>>> account.
> >>>>>>>>>>> Do I need to do anything to be a mentor for RTEMS?
> >>>>>>>>>>> Alan
> >>>>>>>>>>> On Thu, Mar 13, 2014 at 7:31 PM, Andre Marques <
> >>>>>>>>>>> It is now on melange too.
> >>>>>>>>>>> --André Marques.
> >>>>>>>>>>> On 03/13/14 23:21, Hesham Moustafa wrote:
> >>>>>>>>>>> Hi Andre,
> >>>>>>>>>>> I quote from RTEMS SoC page :
> >>>>>>>>>>> "GSOC STUDENTS! PLEASE FILL IN THE APPLICATION AT
> >>>>>>>>>>> http://www.google-melange.com ! YOU CAN EDIT UNTIL THE
> >>>>>>>>>>> DEADLINE!
> >>>>>>>>>>> BUT
> >>>>>>>>>>> YOU WILL NOT GET A SLOT IF YOU DO NOT APPLY THROUGH
> >>>>>>>>>>> Google!!!"
> >>>>>>>>>>> Regards,
> >>>>>>>>>>> Hesham
> >>>>>>>>>>> On Fri, Mar 14, 2014 at 1:16 AM, Andre Marques <
> >>>>>>>>>>> Hello,
> >>>>>>>>>>> I just posted the first proposal draft for "Raspberry Pi
> >>>>>>>>>>> BSP
> >>>>>>>>>>> Peripherals " in the RTEMS Wiki
> >>>>>>>>>>> http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode
> >>>>>>>>>>> Any feedback is more than welcome. Should I post it
> >>>>>>>>>>> already in
> >>>>>>>>>>> melange too?
> >>>>>>>>>>> --André Marques.
> >>>>>>>>>>> On 03/13/14 15:26, Joel Sherrill wrote:
> >>>>>>>>>>> On 3/13/2014 9:46 AM, Andre Marques wrote:
> >>>>>>>>>>> Hello,
> >>>>>>>>>>> I would be very interested in working in this project
> >>>>>>>>>>> because I'm
> >>>>>>>>>>> currently trying to work with Raspberry Pi and RTEMS for
> >>>>>>>>>>> my
> >>>>>>>>>>> undergraduate thesis, so this could be a great followup
> >>>>>>>>>>> to
> >>>>>>>>>>> that for
> >>>>>>>>>>> the summer.
> >>>>>>>>>>> I will need to do some reseach on it before making a
> >>>>>>>>>>> proposal (the
> >>>>>>>>>>> time is also gettting shorter), but will post a proposal
> >>>>>>>>>>> draft very
> >>>>>>>>>>> soon.
> >>>>>>>>>>> This would be a great area to work. As Alan says, the
> >>>>>>>>>>> list is
> >>>>>>>>>>> likely
> >>>>>>>>>>> too much for
> >>>>>>>>>>> one student, so it seems likely that the work could be
> >>>>>>>>>>> divided for
> >>>>>>>>>>> two students
> >>>>>>>>>>> working on different parts.
> >>>>>>>>>>> For the Pi Master list, I would like to add the Geert
> >>>>>>>>>>> board.
> >>>>>>>>>>> That
> >>>>>>>>>>> looks like something
> >>>>>>>>>>> of interest to RTEMS folks.
> >>>>>>>>>>> --joel
> >>>>>>>>>>> --André Marques.
> >>>>>>>>>>> On 03/13/14 11:23, Alan Cudmore wrote:
> >>>>>>>>>>> ( I posted this to the rtems-devel list by mistake, my
> >>>>>>>>>>> apologies
> >>>>>>>>>>> for
> >>>>>>>>>>> the duplicate message )
> >>>>>>>>>>> f there are still potential GSOC students out there
> >>>>>>>>>>> looking
> >>>>>>>>>>> for a
> >>>>>>>>>>> project, I would like to offer a potential project to
> >>>>>>>>>>> work on:
> >>>>>>>>>>> Improving the Raspberry Pi BSP. I would be happy to
> >>>>>>>>>>> mentor a
> >>>>>>>>>>> student
> >>>>>>>>>>> for this project. Below is my description for the task.
> >>>>>>>>>>> Thanks,
> >>>>>>>>>>> Alan
> >>>>>>>>>>> One of the RTEMS Open Projects is to contribute a BSP or
> >>>>>>>>>>> Board
> >>>>>>>>>>> Support Package for readily available boards. The
> >>>>>>>>>>> Raspberry
> >>>>>>>>>>> Pi is
> >>>>>>>>>>> probably the most available board at $25 and $35 USD, and
> >>>>>>>>>>> there
> >>>>>>>>>>> have
> >>>>>>>>>>> been over two million of these boards sold. The RTEMS
> >>>>>>>>>>> head
> >>>>>>>>>>> (4.11)
> >>>>>>>>>>> currently has a basic BSP for the Raspberry Pi,
> >>>>>>>>>>> supporting
> >>>>>>>>>>> the CPU,
> >>>>>>>>>>> a single UART, and timer. It is enough to run some basic
> >>>>>>>>>>> RTEMS
> >>>>>>>>>>> programs, but expanding the BSP to support peripherals
> >>>>>>>>>>> will
> >>>>>>>>>>> make it
> >>>>>>>>>>> much more useful.
> >>>>>>>>>>> For this project, the GSOC student could improve the
> >>>>>>>>>>> peripheral
> >>>>>>>>>>> support for the Raspberry Pi BSP.
> >>>>>>>>>>> The peripherals we need to support (in order of
> >>>>>>>>>>> increasing
> >>>>>>>>>>> difficulty) include:
> >>>>>>>>>>> 1. GPIO (This has been done by one user, but is not
> >>>>>>>>>>> integrated)
> >>>>>>>>>>> 2. I2C Bus
> >>>>>>>>>>> 3. SPI Bus
> >>>>>>>>>>> 4. Secure Digital card read and write support (using the
> >>>>>>>>>>> SPI
> >>>>>>>>>>> bus)
> >>>>>>>>>>> 5. Graphics / RTEMS Framebuffer Support (I have a
> >>>>>>>>>>> graphics demo
> >>>>>>>>>>> working in an RTEMS task)
> >>>>>>>>>>> 6. USB Device support
> >>>>>>>>>>> 7. HDMI/Graphics console (Requires framebuffer support
> >>>>>>>>>>> and
> >>>>>>>>>>> USB or
> >>>>>>>>>>> GPIO connected keyboard device)
> >>>>>>>>>>> 8. Ethernet network support (Requires USB support)
> >>>>>>>>>>> The entire list is probably too much for a single student
> >>>>>>>>>>> to
> >>>>>>>>>>> accomplish, so we can adjust the list of work according
> >>>>>>>>>>> to
> >>>>>>>>>>> what is
> >>>>>>>>>>> possible.
> >>>>>>>>>>> It may also be a good idea to add support for both models
> >>>>>>>>>>> of
> >>>>>>>>>>> the
> >>>>>>>>>>> Raspberry Pi (256MB and 512MB) and be able to configure
> >>>>>>>>>>> the
> >>>>>>>>>>> memory
> >>>>>>>>>>> map in the BSP to match the boot time split between the
> >>>>>>>>>>> CPU
> >>>>>>>>>>> and GPU
> >>>>>>>>>>> memory.
> >>>>>>>>>>> Finally, in order to do some of this coding, it may be
> >>>>>>>>>>> necessary to
> >>>>>>>>>>> come up with a more efficient way to load and debug code
> >>>>>>>>>>> on the
> >>>>>>>>>>> Raspberry Pi. Options include using U-boot or connecting
> >>>>>>>>>>> a JTAG
> >>>>>>>>>>> debug device to load code.
> >>>>>>>>>>> _______________________________________________
> >>>>>>>>>>> rtems-users mailing list rtems-users at rtems.org
> >>>>>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
> >>>>>>>>>>> Joel Sherrill, Ph.D. Director of Research & Development
> >>>>>>>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
> >>>>>>>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >>>>>>>>>>> Support Available (256) 722-9985
> >>>>>>>>>> Pierre FICHEUX -/- CTO OW/OWI, France -\-
> >>>>>>>>>> http://ingenierie.openwide.fr
> >>>>>>>>>> http://www.linuxembedded.fr
> >>>>>>>>>> I would love to change the world, but they won't give me
> >>>>>>>>>> the
> >>>>>>>>>> source
> >>>>>>>>>> code
> >>>>>>>>> the
> >>>>>>>>> source
> >>>>>>>>> code
> >>>>>>>> Development
> >>>>>>>> Research
Pierre FICHEUX -/- CTO OW/OWI, France -\- pierre.ficheux at openwide.fr
I would love to change the world, but they won't give me the source code
