source builder issue (unstable: expat-2.1.0-1 missing)
Sun Mar 23 22:28:36 UTC 2014
On 24/03/2014 7:30 am, Karel Gardas wrote:
> On 03/19/14 02:19 AM, Chris Johns wrote:
>>> For me stable is perfectly OK! What I just need to find out is the most
>>> stable LEON3/SPARC/RTEMS toolchain.
>> It depends if you need SMP or not. I think SMP needs a release branch.
>> Sebastian knows the specifics. I am waiting for the 4.8 branch release
>> to happen.
> Should this be 4.11 release? I.e. typo 4.8->4.11?
The gcc 4.8 branch.
>>> What you guys generally prefer some
>>> LEON3/FPGA board or some simulator for it? I'm asking since I've tested
>>> SIS BSP both with RTEMS tester's sis and sis-run bsp and the results are
>>> different:
>>> sis:
>>> Passed: 465
>>> Failed: 3
>>> Timeouts: 6
>>> Invalid: 1
>>> Total: 475
>>> sis-run:
>>> Passed: 197
>>> Failed: 272
>>> Timeouts: 3
>>> Invalid: 3
>>> Total: 475
>>> The RTEMS tools built with source-builder on Sunday, the RTEMS code
>>> obtained from git also on Sunday. Is this perhaps some issue with
>>> command line sis tool I've already noted in this email thread?
>> Interesting and thanks for using the rtems-test command. There is a
>> patch about for the SPARC simulator to fix the output. I am not sure if
>> this is included in the gdb build. What is the error ? The log should
>> list the details of the tests that are in error. I should mention the
>> number of concurrent tests running can effect the results. It is
>> typically safe to have a test per core and you can go higher but there
>> may be failures.
> I think I just run tests with simple make not using any -jX option.
> Shall I?
The rtems-test command has a --jobs option that controls the number of
parallel tests. I am not sure I follow where make is involved when using
> The error is this:
> [karel at centos sis-bsp]$ sparc-rtems4.11-sis
>   SIS - SPARC instruction simulator 2.7.5,  copyright Jiri Gaisler 1995
>   Bug-reports to jgais at wd.estec.esa.nl
> sis> load ./sparc-rtems4.11/c/sis/testsuites/samples/hello/hello.exe
> sis> go
> resuming at 0x02000000
> *** HELLO WORLD TEST ***
> Hello World
> *** END OF HELLO WORLD TEST ***
> IU in error mode (257)
>     128835  02001f38  91d02000  Address 0x0000000002001f38 is out of
> bounds.
> sis>
> I mean this "IU in error mode (257)
> bounds." message...
I do not think there is any support for the sis command. There is
support for gdb and the run command.
