[ESA summer of code, 2014] RTEMS testing
Kumar Amit Mehta gmate.amit at gmail.com
Tue May 13 15:27:01 UTC 2014
On Tue, May 13, 2014 at 06:21:08PM +0300, Kumar Amit Mehta wrote:
> Hi,
> I've some queries regarding the testing framework for rtems.
> 1: There seem to be two different set of framework and set of tests.
> First one [1] is part of rtems package itself and the second one [2]
> seem to have a different git repository and is written in Python.
> How are these two different ?
> 2: I ran the simple hello world test case on the simulator, then
> I also ran all those ~490 test cases that were part of rtems-tools
> tests[2]. According to the information on the ESA summer of code page
> of RTEMS [4], RTEMS testing using 'C' and 'C++' (seems like cmock is
> the favorite right now [3]) is a prospective candidate for ESA summer
> of code. I just want to be sure that It is still the case, Therefore,
> CC'd mentors for RTEMS testing [4] here.
> 3: Is there a guide or link on running rtems test suite [1] (I ran
> the modified hello world program on the simulator, but was wondering,
> If those standalone test cases can be run as a batch, one after
> another)
> [1] http://git.rtems.org/rtems/tree/testsuites
> [2] git://git.rtems.org/rtems-tools.git
> [3] http://www.rtems.org/wiki/index.php/TestingReview
> [4] http://www.rtems.org/wiki/index.php/RTEMS_Testing
Resending the mail, as the delivery to one of the mentor(Amar) failed
due to typo mistake from my side. My apologies.
Thanks,
Kumar
