RTEMS - FreeBSD TFTP test problem.
Thomas Kim
thomas73.kim at gmail.com
Thu May 15 06:42:40 UTC 2014
Dear Sir,
I am testing RTEMS FreeBSD networking using
network-demos-network-demos-4.10.2.
At this time, testing code about dnstest, http are OK.
When I try to test tftpTest, there is below problem.
Function flow for TFTP request is below;
- rtems_tftp_open()
- rtems_tftp_open_worker()
- sendto()
- udp_output()
- ip_output() ==> My problem is here !!!
Normal case using TCP, if_output() function entry in ip_output is
ether_output().
But, abnormal case using UDP, if_output() function entry is looutout().
It mean that UDP is tring to use loopback interface.
I don't know the reason about this problem.
Please could you let me know how to resolve this ?
Best Regards.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140515/c1dc5e07/attachment.html>
