Is there a bug using select() ?
Thomas Kim
thomas73.kim at gmail.com
Thu May 22 09:09:27 UTC 2014
Dear Sir,
I am tring to integrate POSIX application on RTEMS.
our POSIX application use select() for I/O multiplexing mechanism.
At this time, select() always return "-1" value, it mean "bad file number".
Therefore, I tested simple test code using select() function in below;
Is it a bug using select() ? and, Is there how to do fix this problem ?
void test_select(void)
int fd[2];
int i;
int n;
int state;
char buf[255];
struct timeval tv;
fd_set readfds, writefds;
mkdir ("tmp", S_IRWXU|S_IRWXG|S_IRWXO);
if ((fd[0] = open("/tmp/testfile", O_CREAT | O_RDONLY)) == -1)
printf("file open error : ");
exit(0);
if ((fd[1] = open("/tmp/testfile2", O_CREAT | O_RDONLY)) == -1)
exit(0);
memset (buf, 0x00, 255);
for(;;)
FD_ZERO(&readfds);
FD_SET(fd[0], &readfds);
FD_SET(fd[1], &readfds);
state = select(fd[1]+1, &readfds, NULL, NULL, NULL);
switch(state)
case -1:
perror("select error : ");
exit(0);
break;
default :
for (i = 0; i < 2; i++)
if (FD_ISSET(fd[i], &readfds))
while ((n = read(fd[i], buf, 255)) > 0)
printf("(%d) [%d] %s", state, i, buf);
break;
usleep(1000);
Best Regards.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140522/f60445da/attachment.html>
