RTEMS shell and telnetd
Wed May 28 15:13:11 UTC 2014
On Wed, May 28, 2014 at 11:04 AM, Peter Dufault <dufault at hda.com> wrote:
> I'm figuring out how we're supposed to hook telnetd and RTEMS shell together in the git head and I don't understand the intent.  I used to do it like this:
> static void sh_wrap(char *unused_dev, void *arg)
>     rtems_shell_env_t my_env = rtems_global_shell_env;
>     my_env.forever = false;
>     (void)rtems_shell_main_loop( &my_env );
> rtems_telnetd_config_table rtems_telnetd_config = {
>     sh_wrap,                /* Command */
>     NULL,                   /* Argument */
>     0,                      /* Priority */
>     20 * RTEMS_MINIMUM_STACK_SIZE, /* task stack size */
>     0,                      /* Login check */
>     0                       /* Keep stdio of the caller  */
> and later call:
>     rtems_telnetd_initialize();
> "rtems_global_shell_env" is no longer global.  "rtems_shell_init_env()" which would initialize a rtems_shell_env_t is not global.  "rtems_shell_get_current_env()" won't work outside of a shell context.  Passing 0 to rtems_shell_main_loop(0) will get the default settings for the shell env, so forever will be set true and I won't be able to exit the session.
> Am I missing something or is the intention I set up a "my_env" myself?  rtems_shell_env_t is still global.
This appears to be a side-effect of
http://git.rtems.org/rtems/commit/?id=6cd4a5ca2e2211c4008d99fc272412c9b03c86ce
I'm not sure about the intent. Perhaps someone at Embedded Brains may comment.
Gedare
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> rtems-users mailing list
> rtems-users at rtems.org
