RTEMS shell and telnetd
Christian Mauderer
list+rtems at c-mauderer.de
Thu May 29 18:17:27 UTC 2014
Am 28.05.2014 17:13, schrieb Gedare Bloom:
> On Wed, May 28, 2014 at 11:04 AM, Peter Dufault <dufault at hda.com> wrote:
>> I'm figuring out how we're supposed to hook telnetd and RTEMS shell together in the git head and I don't understand the intent. I used to do it like this:
>> static void sh_wrap(char *unused_dev, void *arg)
>> rtems_shell_env_t my_env = rtems_global_shell_env;
>> my_env.forever = false;
>> (void)rtems_shell_main_loop( &my_env );
>> rtems_telnetd_config_table rtems_telnetd_config = {
>> sh_wrap, /* Command */
>> NULL, /* Argument */
>> 0, /* Priority */
>> 20 * RTEMS_MINIMUM_STACK_SIZE, /* task stack size */
>> 0, /* Login check */
>> 0 /* Keep stdio of the caller */
>> and later call:
>> rtems_telnetd_initialize();
>> "rtems_global_shell_env" is no longer global. "rtems_shell_init_env()" which would initialize a rtems_shell_env_t is not global. "rtems_shell_get_current_env()" won't work outside of a shell context. Passing 0 to rtems_shell_main_loop(0) will get the default settings for the shell env, so forever will be set true and I won't be able to exit the session.
>> Am I missing something or is the intention I set up a "my_env" myself? rtems_shell_env_t is still global.
> This appears to be a side-effect of
> http://git.rtems.org/rtems/commit/?id=6cd4a5ca2e2211c4008d99fc272412c9b03c86ce
> I'm not sure about the intent. Perhaps someone at Embedded Brains may comment.
> Gedare
This patch allows the code to be used with SMP.
See http://www.rtems.org/wiki/index.php/SMP#Task_Variables
Kind Regards
Christian Mauderer
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
