Rehosting Update
Thu Nov 20 16:00:56 UTC 2014
On Thu, Nov 20, 2014 at 10:54 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> https://devel.rtems.org/ is now up with our Trac instance.
> As mentioned in a previous update, this merges Bugzilla and
> Mediawiki. All the old content is there but it has likely moved
> around. If you spot something broken or out of date, fix it
> or report it.
Piling on, the long-term plan is to relocate user-oriented content
from the wiki into other manuals and web sites, and to focus the Trac
wiki on RTEMS development. You can see the list of pages that will
eventually be relocated at https://devel.rtems.org/wiki/TitleIndex
searching for TBR.
-Gedare
> Old bugzilla accounts have been migrated to Trac but the passwords
> all need to be reset.  The accounts the account portion of an email
> so for user at example.com, it would be "user". Mine is joel.sherrill
> since I use joel.sherrill at oarcorp.com.
> Passwords must be reset emails will go to the registered account email.
> If anyone has problems, email amar at rtems.org.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
