MPC55xx, <spe.h>, and <stdlib.h> and who owns what
Wed Nov 26 13:10:32 UTC 2014
The last time I looked at the <spe.h> it was horribly broken. Its a
shame that it found its way into the GCC sources.
This <machine/stdlib.h> is from Newlib.
On 26/11/14 13:56, Peter Dufault wrote:
> I'm trying to figure out who to report a bug to.
> One of my clients started using <spe.h> for the MPC55XX Signal Processing Extensions, and that header has some problems.  It defines it's own versions of int32_t and friends that conflict with what's in <stdint.h>, and it has definitions of some SPE functions, for example these:
> /* The SPE PIM says these are declared in <spe.h>, although they are
>     not provided by GCC: they must be taken from a separate
>     library.  */
> extern short int atosfix16 (const char *);
> extern int atosfix32 (const char *);
> extern long long atosfix64 (const char *);
> and these functions have conflicting definitions in <machine/stdlib.h>.
> <spe.h> is obviously from GCC, but I don't see a copyright in <machine/stdlib.h>
> Who owns that file?  Are these both part of GCC?  Does anyone know if it is kosher to suggest including <stdlib.h> in <spe.h> to get around these problems?
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
