RTEMS crash with mem address not aligned failure
Fri Oct 3 21:03:40 UTC 2014
On 3/10/2014 7:40 pm, Hoefle Marco wrote:
> Hello,
> to debug the Filesystem getcwd behavior we want to try latest mainline
> RTEMS4.11 for SPARC, LEON3 BSP if the error is still there.
> Our application consists for test purpose only of the RTEMS shell and a
> dummy task
> Starting 1 threads...
> started thread 0: id: 0x0b010002, prio: 10
>   starting shell
> RTEMS SHELL (Ver.1.0-FRC):/dev/console. Sep 30 2014. 'help' to list
> commands.
> [/] # hello dude, this is tick nr: 1
> hello dude, this is tick nr: 2
> [/] # ls
> dev
> Afterwards typing the ls command into the shell the debugger quits with
> the error:
> grmon2> load cassis.elf; run
>    40000000 .text                    460.4kB / 460.4kB
> [===============>] 100%
>    40073170 .data                      5.1kB /   5.1kB
>    400745D0 .jcr                         4B
>    Total size: 465.46kB (2.04Mbit/s)
>    Entry point 0x40000000
>    Image cassis.elf loaded
>    CPU 0:  IU in error mode (tt = 0x07, mem address not aligned)
>            0x40005310: c201a010  ld  [%g6 + 0x10], %g1
> <malloc_is_system_state_OK+0>
>    CPU 1:  Power down mode
> Could this be a newlib issue? We are using:
Is the memory map ok for the BSP ? It pays when moving to 4.11 from 4.10
to check the memory map is ok.
> # Tools configuration.
> 4.11/rtems-autotools
> devel/expat-2.1.0-1
> tools/rtems-binutils-2.24-1
> tools/rtems-gcc-4.7.3-newlib-2.0.0-1
> tools/rtems-gdb-7.7-1
> tools/rtems-kernel-4.11
> We are using rtems-source-builder for building toolchain and kernel but
> the suggested newlib cvs repo is down so we switched to an older one.
I found this https://sourceware.org/git/?p=newlib.git;a=summary repo so
I wonder if newlib has or is moving to git or this is a conversion.
I am going to test using this repo rather than cvs.
