RTEMS crash with mem address not aligned failure
Rafael Morales
rmorales at iaa.es
Fri Oct 3 15:43:14 UTC 2014
Dear Marco,
I had also a headeach with EDAC problems (memory not aligned, traps ...).
My personal suggestion is that you clean the memory ( in grmon use the
"wash" command) and then run the test again.
Saludos Rafa.
> Hello,
> to debug the Filesystem getcwd behavior we want to try latest mainline
> RTEMS4.11 for SPARC, LEON3 BSP if the error is still there.
> Our application consists for test purpose only of the RTEMS shell and
> a dummy task
> Starting 1 threads...
> started thread 0: id: 0x0b010002, prio: 10
> starting shell
> RTEMS SHELL (Ver.1.0-FRC):/dev/console. Sep 30 2014. 'help' to list
> commands.
> [/] # hello dude, this is tick nr: 1
> hello dude, this is tick nr: 2
> [/] # ls
> dev
> Afterwards typing the ls command into the shell the debugger quits
> with the error:
> grmon2> load cassis.elf; run
> 40000000 .text 460.4kB / 460.4kB
> [===============>] 100%
> 40073170 .data 5.1kB / 5.1kB
> 400745D0 .jcr 4B [===============>] 100%
> Total size: 465.46kB (2.04Mbit/s)
> Entry point 0x40000000
> Image cassis.elf loaded
> CPU 0: IU in error mode (tt = 0x07, mem address not aligned)
> 0x40005310: c201a010 ld [%g6 + 0x10], %g1
> <malloc_is_system_state_OK+0>
> CPU 1: Power down mode
> Could this be a newlib issue? We are using:
> # Tools configuration.
> 4.11/rtems-autotools
> devel/expat-2.1.0-1
> tools/rtems-binutils-2.24-1
> tools/rtems-gcc-4.7.3-newlib-2.0.0-1
> tools/rtems-gdb-7.7-1
> tools/rtems-kernel-4.11
> We are using rtems-source-builder for building toolchain and kernel
> but the suggested newlib cvs repo is down so we switched to an older one.
> Thanks,
> Marco
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20141003/f56e0e9c/attachment.html>
