RTEMS crash with mem address not aligned failure
Mon Oct 6 06:08:05 UTC 2014
On 04/10/14 07:07, Chris Johns wrote:
>>> Could this be a newlib issue? We are using:
>> Is the memory map ok for the BSP ? It pays when moving to 4.11 from 4.10
>> to check the memory map is ok.
> I can confirm this happens on the SIS bsp in simulator using the fileio.exe
> example. Run the sample, hit a key, start the shell and enter ls.
I don't see this problem here.  I use sparc-rtems4.11-gcc 4.9.2 20140924 with
the latest Newlib.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
