RTEMS crash with mem address not aligned failure
Mon Oct 6 07:03:52 UTC 2014
On 6/10/2014 5:08 pm, Sebastian Huber wrote:
> On 04/10/14 07:07, Chris Johns wrote:
>>>> Could this be a newlib issue? We are using:
>>> Is the memory map ok for the BSP ? It pays when moving to 4.11 from 4.10
>>> to check the memory map is ok.
>> I can confirm this happens on the SIS bsp in simulator using the
>> fileio.exe
>> example. Run the sample, hit a key, start the shell and enter ls.
> I don't see this problem here.  I use sparc-rtems4.11-gcc 4.9.2 20140924
> with the latest Newlib.
Do you see it with the RSB tools ?
