Debugging on ZedBoard BSP?
Steve B
sbattazzo at gmail.com
Tue Oct 7 17:06:35 UTC 2014
Hello,
I was trying to get an application up and running on the ZedBoard BSP, but
haven't had much luck debugging.
I can try loading the application binary either through XMD, or through the
arm-rtems-4.11-gdb and it seems to crash out fairly consistently, and
leaving me no stack trace to see what was last executed (so I assume the
stack has overflowed or is otherwise corrupted?). If I try to set any
breakpoints, the program crashes somewhere before where it would crash if I
let it run freely, and once again I have nothing to backtrace.
Does anyone have any experience trying to single step debug on the ZedBoard?
Cheers,
Steve
URL: <http://lists.rtems.org/pipermail/users/attachments/20141007/44f2439d/attachment.html>
