The error in building rtems source about stm32f4 bsp
Wed Oct 29 14:19:32 UTC 2014
Hi,
If you just do 'make' without 'make install', does your build complete
successfully?
On Wed, Oct 29, 2014 at 10:07 AM, ZhangZhenxing <harbor0727 at gmail.com> wrote:
> Hi,
> I got the rtems source builder by the git command("git clone
> git://git.rtems.org/rtems-source-builder.git") and builded rtems 4.11
> toolschain by rtems source builder with the configure
> command("../rtems-4.10.99/configure --target=arm-rtems4.11 --enable-posix
> --enable-networking --enable-cxx --enable-rtemsbsp=stm32f4
> --prefix=/opt/rtems-4.11/"). Then, when executing "sudo make all install"
> after "./configure", there is a error as follow. Why is it? How can I do for
> it? Thank you very much!
> make[8]: Entering directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm/stm32f4'
> /usr/bin/install -c -m 644
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/bsp_specs
> ../../../../../.././stm32f4/lib/bsp_specs
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/tm27.h
> ../../../../../.././stm32f4/lib/include/tm27.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/bsp.h
> ../../../../../.././stm32f4/lib/include/bsp.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/coverhd.h
> ../../../../../.././stm32f4/lib/include/coverhd.h
> /usr/bin/install -c -m 644 include/bspopts.h
> ../../../../../.././stm32f4/lib/include/bspopts.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/bootcard.h
> ../../../../../.././stm32f4/lib/include/bsp/bootcard.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/utility.h
> ../../../../../.././stm32f4/lib/include/bsp/utility.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-generic.h
> ../../../../../.././stm32f4/lib/include/bsp/irq-generic.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-info.h
> ../../../../../.././stm32f4/lib/include/bsp/irq-info.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/stackalloc.h
> ../../../../../.././stm32f4/lib/include/bsp/stackalloc.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/include/start.h
> ../../../../../.././stm32f4/lib/include/bsp/start.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/armv7m/include/armv7m-irq.h
> ../../../../../.././stm32f4/lib/include/bsp/armv7m-irq.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/irq.h
> ../../../../../.././stm32f4/lib/include/bsp/irq.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/usart.h
> ../../../../../.././stm32f4/lib/include/bsp/usart.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f4.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_gpio.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_gpio.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_rcc.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_rcc.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_exti.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_exti.h
> make[8]: *** No rule to make target `include/stm32f4xxxx_adc.h', needed by
> `../../../../../.././stm32f4/lib/include/bsp/stm32f4xxxx_adc.h'. Stop.
> make[8]: Leaving directory
> make[7]: *** [preinstall-recursive] Error 1
> make[7]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm'
> make[6]: *** [preinstall-recursive] Error 1
> make[6]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp'
> make[5]: *** [preinstall-recursive] Error 1
> make[5]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib'
> make[4]: *** [preinstall-recursive] Error 1
> make[4]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4'
> make[3]: *** [preinstall-stamp] Error 2
> make[3]: Leaving directory
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c'
> make: *** [all-recursive] Error 1
> ________________________________
> users mailing list
> users at rtems.org
