The error in building rtems source about stm32f4 bsp
    ZhangZhenxing
    harbor0727 at gmail.com
    Wed Oct 29 14:59:14 UTC 2014
On 10/29/2014 9:07 AM, ZhangZhenxing wrote:
> Hi,
> I got the rtems source builder by the git command("git clone
> git://git.rtems.org/rtems-source-builder.git") and builded rtems 4.11
> toolschain by rtems source builder with the configure
> command("../rtems-4.10.99/configure --target=arm-rtems4.11
> --enable-posix --enable-networking --enable-cxx
> --enable-rtemsbsp=stm32f4 --prefix=/opt/rtems-4.11/"). Then, when
> executing "sudo make all install" after "./configure", there is a
> error as follow. Why is it? How can I do for it? Thank you very much!
I can confirm that I got the same message in a full build I ran Oct 26
but just now got a
chance to look at. Using git blame, I see it was the last patch from
Chris Nott[1]. It looks
like the patch added some files to the Makefile.am but didn't include them.
Chris.. if you can submit a patch which adds the new files, I will merge
it quickly. At the
moment, no stm32f*is building.
http://git.rtems.org/rtems/commit/?id=040ed0b4cdd1c663408664ba3a8b2e5de0cf54e0
You could locally revert that patch and continue until it is resolved in
the master. This is
just part of using the development head. 99% of the time it is OK but
once in a while,
it isn't.
[1] Sorry I missed having lunch or dinner with you. :)
> make[8]: Entering directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm/stm32f4'
> /usr/bin/install -c -m 644
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/bsp_specs
> ../../../../../.././stm32f4/lib/bsp_specs
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/tm27.h
> ../../../../../.././stm32f4/lib/include/tm27.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/bsp.h
> ../../../../../.././stm32f4/lib/include/bsp.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/coverhd.h
> ../../../../../.././stm32f4/lib/include/coverhd.h
> /usr/bin/install -c -m 644 include/bspopts.h
> ../../../../../.././stm32f4/lib/include/bspopts.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/bootcard.h
> ../../../../../.././stm32f4/lib/include/bsp/bootcard.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/utility.h
> ../../../../../.././stm32f4/lib/include/bsp/utility.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-generic.h
> ../../../../../.././stm32f4/lib/include/bsp/irq-generic.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-info.h
> ../../../../../.././stm32f4/lib/include/bsp/irq-info.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/stackalloc.h
> ../../../../../.././stm32f4/lib/include/bsp/stackalloc.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/include/start.h
> ../../../../../.././stm32f4/lib/include/bsp/start.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/armv7m/include/armv7m-irq.h
> ../../../../../.././stm32f4/lib/include/bsp/armv7m-irq.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/irq.h
> ../../../../../.././stm32f4/lib/include/bsp/irq.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/usart.h
> ../../../../../.././stm32f4/lib/include/bsp/usart.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f4.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_gpio.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_gpio.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_rcc.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_rcc.h
> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_exti.h
> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_exti.h
> make[8]: *** No rule to make target `include/stm32f4xxxx_adc.h',
> needed by
> `../../../../../.././stm32f4/lib/include/bsp/stm32f4xxxx_adc.h'. Stop.
> make[8]: Leaving directory
> make[7]: *** [preinstall-recursive] Error 1
> make[7]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm'
> make[6]: *** [preinstall-recursive] Error 1
> make[6]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp'
> make[5]: *** [preinstall-recursive] Error 1
> make[5]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib'
> make[4]: *** [preinstall-recursive] Error 1
> make[4]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4'
> make[3]: *** [preinstall-stamp] Error 2
> make[3]: Leaving directory
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c'
> make: *** [all-recursive] Error 1
URL: <http://lists.rtems.org/pipermail/users/attachments/20141029/4b3b1078/attachment-0002.html>
