Memory protection in RTEMS
Thu Apr 2 15:01:38 UTC 2015
Hi Tomasz,
It is possible to implement some memory protection between threads. As
you noticed, RTEMS is a SASOS with "one process" when viewed from the
POSIX interface. Generalizing memory protection in such a system is
hard. The most common approach I know of is to provide separate
protection domains for each thread stack. In theory, you could create
a protection domain for the RTEMS "kernel", but I'm not aware of
anyone that has tried hard to do that. You may also look for the "Zero
Kernel" work some folks did as a research project at Univ of Idaho I
think it was.
If you want memory protection, you'd have to tailor it to your
specific application requirements and set-up the MMU/MPU to do it.
Final note: Since there is no notion of privilege in RTEMS, any thread
can always disable or modify the protection domains since priviliged
registers and instructions are available. Thus, while you may add
memory protection, it would not be for a complete security solution.
Gedare
On Thu, Apr 2, 2015 at 10:04 AM, Tomasz Gregorek
<tomasz.gregorek at gmail.com> wrote:
> Hi
> We are investigating possible OSes for a new product where one of the
> requirements is memory protection between processes.
> Does RTEMS supports memory protection? If not than is it planned to
> implement memory protection?
> This is what I found so far:
> RTEMS is single process, multiple threads and as such have everything in
> single memory space.
> http://comments.gmane.org/gmane.os.rtems.user/19858
> Gedare's blog with his implementation of memory protection from 2011/2012.
> http://gedare-csphd.blogspot.be/2011/12/rtems-memory-protection-api.html
> but it seems that this code didn't get to the main.
> Project "MMU Support" by Aanjhan Ranganathan from 6 years ago:
> https://devel.rtems.org/wiki/Projects/MMU_Support
> Source code configures MMUs but it seems it do it to enable cache only, not
> the memory protection. Though I did only simple search through the code.
> There are exception handlers for some architectures/CPUs but only for few if
> not for only one.
> Best regards
> Tomasz Gregorek
> users mailing list
> users at rtems.org
