attaching an interrupt in beaglebone bsp
angelo fraietta
newsgroups at smartcontroller.com.au
Wed Apr 15 05:07:27 UTC 2015
Have you had a look at
http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
Apparently ticker and termios use interrupts, so look at those and see
what you can come up with. Let us all know when you find out.
Thanks
On 13/04/2015 10:14 PM, Andrew Harris wrote:
> Hello,
> I'm not sure how to attach an interrupt in the beaglebone ARM bsp.
> I learned that the "rtems_interrupt_catch" method of binding an
> interrupt to an ISR won't work by noticing that the
> CPU_SIMPLE_VECTORED_INTERRUPTS is set to FALSE in cpu.h for the
> beaglebone BSP. I want to try binding an interrupt from the I2C Bus 1
> into RTEMS, but I'm not sure where to go next in terms of how to
> attach the interrupt. Any help would be appreciated.
> -andrew
> users mailing list
> users at rtems.org
This email has been checked for viruses by Avast antivirus software.
http://www.avast.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20150415/08c7e3e5/attachment.html>
