Can't seem to fill up my RFS filesystem
Mohammed Saeed Khoory Mohammed.Khoory at eiast.ae
Sun Apr 19 09:57:17 UTC 2015
I've fixed my issue by manually increasing the block size to 1024 (previously it was 512 which was the default). This caused the number of groups in the filesystem to be equal to 1. I am now able to fill up the filesystem as expected.
I still cannot explain what was causing the problem however. But I guess that in order to explain it, one would need to go into a lot of fine detail about RFS.
I hope this helps anyone facing the same issue.
> -----Original Message-----
> From: users [mailto:users-bounces at rtems.org] On Behalf Of Mohammed Saeed
> Khoory
> Sent: Sunday, April 19, 2015 10:47 AM
> To: 'rtems-users at rtems.org'
> Subject: Can't seem to fill up my RFS filesystem
> Hi,
> I'm using RTEMS 4.10.2 with a LEON3-FT, and I've noticed a strange issue
> with my RFS-formatted RAMDisk. My RAMDisk has a total capacity of 6MB, and
> I'm using default values for formatting it with RFS. It seems that at some
> point, I cannot open or write to files, with write() and open() returning
> ENOSPC. However, statvfs tells me that I have around 2MB left, so this
> shouldn't happen.
> While investigating, I wrote a small test with my code, where it opens a
> file, writes 8000 bytes to it, then closes it, and repeats, until it
> encounters an error. In between, I print out the results of the shell
> command "debugrfs group". This is what I got
> Writing file 960 of 100000 with 8000 bytes, size free: 1995264
>     0: base=1       size=4096   blocks=4096  (100%) inode=369   (100%)
>     1: base=4097    size=4096   blocks=4096  (100%) inode=136   ( 36%)
>     2: base=8193    size=4095   blocks=216   (  5%) inode=0     (  0%)
> Writing file 961 of 100000 with 8000 bytes, size free: 1986560
>     1: base=4097    size=4096   blocks=4096  (100%) inode=137   ( 37%)
>     2: base=8193    size=4095   blocks=233   (  5%) inode=0     (  0%)
> Writing file 962 of 100000 with 8000 bytes, size free: 1977856
>     1: base=4097    size=4096   blocks=4096  (100%) inode=138   ( 37%)
>     2: base=8193    size=4095   blocks=250   (  6%) inode=0     (  0%)
> Writing file 963 of 100000 with 8000 bytes, size free: 1969152
> open_mod: cannot initially open file, path=/ram:0/00000962.TST, flags=512,
> errno=28
> I've been reading about the structure of RFS at the same time, and while I
> don't fully understand it, I do understand that the filesystem is divided
> into groups, each group having a certain number of blocks that could be
> allocated to files. From the output it seems that the last group isn't
> being used up at all, and allocating space for new files fails, even
> though there's a good amount left.
> I've noticed that there's a bug that I thought might've been related to
> this issue, located here: https://lists.rtems.org/pipermail/bugs/2013-
> December/004658.html . I've patched the 4.10.2 source, however this didn't
> solve the problem. I'm also not sure if this problem exists in 4.11
> Is there any explanation for this?
> Best Regards,
> users mailing list
> users at rtems.org
