Can't seem to fill up my RFS filesystem
Mon Apr 20 03:44:30 UTC 2015
On 19/04/2015 7:57 pm, Mohammed Saeed Khoory wrote:
> I've fixed my issue by manually increasing the block size to 1024 (previously it was 512 which was the default). This caused the number of groups in the filesystem to be equal to 1. I am now able to fill up the filesystem as expected.
> I still cannot explain what was causing the problem however. But I guess that in order to explain it, one would need to go into a lot of fine detail about RFS.
> I hope this helps anyone facing the same issue.
There was a bug where the last group was not being used. I thought this
had been fixed. I will need to take a closer look.
Can you please raise a ticket ?
Thanks
