[rtems-libbsd] Building for zynq?
Jonathan Brandmeyer
jonathan.brandmeyer at gmail.com
Tue Apr 28 17:31:20 UTC 2015
Thanks. My toolchain was a few months old, and its update is proceeding.
I began the update with a simple git pull followed by re-running the
sb-set-builder program, which is continuing to run as I write this.
However, I did not explicitly clean the build or start from a fresh git
checkout of the rtems-source-builder. Will the sb-set-builder tool do The
Right Thing in the "recursive make considered harmful" sense with regard to
dependency tracking?
Phrased differently, is supporting an in-place update an explicitly
supported usage mode for sb-set-builder, or am I expected to start over
from scratch on a new build?
Thanks,
Jonathan Brandmeyer
On Tue, Apr 28, 2015 at 8:18 AM, Sebastian Huber <
> Hello Jonathan,
> you need the latest tools (Newlib in particular must be the up to date) to
> build the libbsd. The Xilinx Zynq is supported.
> ----- Jonathan Brandmeyer <jonathan.brandmeyer at gmail.com> schrieb:
> I'm trying to build rtems-libbsd targeting xilinx_zynq_zedboard and/or
> xilinx_zynq_qemu in order to test out networking with libbsd. At least two
> files/types related to time are missing:
> rtemsbsd/include/rtems/bsd/sys/resource.h includes <sys/_timeval.h> which
> is not present in RTEMS, my BSP, or libbsd. Numerous files then reference
> sys/resource.h
> freebsd/sys/opencrypto/cryptodev.h requests 'struct bintime' to be a
> member, which is an incomplete type. Again, this type is not provided by
> Does libbsd work for the ARM Xilinx targets, and if so, what can I do
> about libbsd's sense of time?
> Thanks,
> Jonathan Brandmeyer
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-brains.de <http://lists.rtems.org/mailman/listinfo/devel>
URL: <http://lists.rtems.org/pipermail/users/attachments/20150428/c991bbaa/attachment.html>
