[rtems-libbsd] Building for zynq?
Jonathan Brandmeyer
jonathan.brandmeyer at gmail.com
Tue Apr 28 18:20:10 UTC 2015
The libbsd build has now failed on a new error: The header file
sys/_stdint.h cannot be found for use by the libutil library and tools that
use it. I note that sys/sys/stdint.h has a #ifndef __rtems__ wrap-around
for that file's reference to <sys/_stdint.h>.
Replacing the #include with <stdint.h> instead does work around the
problem, but I wonder if there isn't some other missing dependency.
This was with a fresh update of both rtems-source-builder, rtems-libbsd,
and rtems mainline source as of this morning.
Thanks,
-Jonathan Brandmeyer
On Tue, Apr 28, 2015 at 11:31 AM, Jonathan Brandmeyer <
jonathan.brandmeyer at gmail.com> wrote:
> Thanks. My toolchain was a few months old, and its update is proceeding.
> I began the update with a simple git pull followed by re-running the
> sb-set-builder program, which is continuing to run as I write this.
> However, I did not explicitly clean the build or start from a fresh git
> checkout of the rtems-source-builder. Will the sb-set-builder tool do The
> Right Thing in the "recursive make considered harmful" sense with regard to
> dependency tracking?
> Phrased differently, is supporting an in-place update an explicitly
> supported usage mode for sb-set-builder, or am I expected to start over
> from scratch on a new build?
> Thanks,
> Jonathan Brandmeyer
> On Tue, Apr 28, 2015 at 8:18 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Jonathan,
>> you need the latest tools (Newlib in particular must be the up to date)
>> to build the libbsd. The Xilinx Zynq is supported.
>> ----- Jonathan Brandmeyer <jonathan.brandmeyer at gmail.com> schrieb:
>> I'm trying to build rtems-libbsd targeting xilinx_zynq_zedboard and/or
>> xilinx_zynq_qemu in order to test out networking with libbsd. At least two
>> files/types related to time are missing:
>> rtemsbsd/include/rtems/bsd/sys/resource.h includes <sys/_timeval.h> which
>> is not present in RTEMS, my BSP, or libbsd. Numerous files then reference
>> sys/resource.h
>> freebsd/sys/opencrypto/cryptodev.h requests 'struct bintime' to be a
>> member, which is an incomplete type. Again, this type is not provided by
>> Does libbsd work for the ARM Xilinx targets, and if so, what can I do
>> about libbsd's sense of time?
>> Thanks,
>> Jonathan Brandmeyer
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de <http://lists.rtems.org/mailman/listinfo/devel>
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20150428/82612c3e/attachment-0002.html>
