Installation query
Thu Aug 6 20:03:59 UTC 2015
You need to build the autotools with RSB to ensure you get the correct
version, and check they are picked up in your PATH.
On Thu, Aug 6, 2015 at 3:14 PM, Sarvesh Patkar <sarveshspatkar at gmail.com> wrote:
> Hi,
> Thanks for the quick reply.
> I tried the steps mentioned on the quickstart page. After downloading RTEMS,
> when I try the bootstrap command, I get several warnings, which go as
> follows.
> Makefile.am:23: warning: source file 'timer/timer.c' is in a subdirectory,
> Makefile.am:23: but option 'subdir-objects' is disabled
> Makefile.am:23: warning: source file 'timer/timerisr.c' is in a
> subdirectory,
> Makefile.am:23: warning: source file 'shmsupp/addrconv.c' is in a
> subdirectory,
> Makefile.am:23: warning: source file 'shmsupp/getcfg.c' is in a
> subdirectory,
> Makefile.am:23: warning: source file 'shmsupp/lock.c' is in a subdirectory,
> Makefile.am:23: warning: source file 'shmsupp/mpisr.c' is in a subdirectory,
> ./c/src/lib/libbsp/no_cpu
> acinclude.m4 is unchanged
> ./c/src
> ./c/src/ada-tests
> mptests/mp01/node1/Makefile.am:9: warning: source file
> '../../../support/init.c' is in a subdirectory,
> mptests/mp01/node1/Makefile.am:9: but option 'subdir-objects' is disabled
> automake: warning: possible forward-incompatibility.
> automake: At least a source file is in a subdirectory, but the
> 'subdir-objects'
> automake: automake option hasn't been enabled.  For now, the corresponding
> output
> automake: object file(s) will be placed in the top-level directory.
> However,
> automake: this behaviour will change in future Automake versions: they will
> automake: unconditionally cause object files to be placed in the same
> subdirectory
> automake: of the corresponding sources.
> automake: You are advised to start using 'subdir-objects' option throughout
> your
> automake: project, to avoid future incompatibilities.
> mptests/mp01/node2/Makefile.am:9: warning: source file
> mptests/mp01/node2/Makefile.am:9: but option 'subdir-objects' is disabled
> mptests/mp02/node1/Makefile.am:9: warning: source file
> mptests/mp02/node1/Makefile.am:9: but option 'subdir-objects' is disabled
> mptests/mp02/node2/Makefile.am:9: warning: source file
> mptests/mp02/node2/Makefile.am:9: but option 'subdir-objects' is disabled
> These warnings repeat themselves for a lot of source files in
> subdirectories. I do not understand how to enable the subdir-objects option.
> Also, at the very end I also get the following messages.
> ada_user/Makefile.am: warning: Oops!
> ada_user/Makefile.am:     It appears this file (or files included by it) are
> triggering
> ada_user/Makefile.am:     an undocumented, soon-to-be-removed automake hack.
> ada_user/Makefile.am:     Future automake versions will no longer place in
> the builddir
> ada_user/Makefile.am:     (rather than in the srcdir) the generated '.info'
> files that
> ada_user/Makefile.am:     appear to be cleaned, by e.g. being listed in
> CLEANFILES or
> ada_user/Makefile.am:     DISTCLEANFILES.
> ada_user/Makefile.am:     If you want your '.info' files to be placed in the
> builddir
> ada_user/Makefile.am:     rather than in the srcdir, you have to use the
> shiny new
> ada_user/Makefile.am:     'info-in-builddir' automake option.
> bsp_howto/Makefile.am: warning: Oops!
> bsp_howto/Makefile.am:     It appears this file (or files included by it)
> are triggering
> bsp_howto/Makefile.am:     an undocumented, soon-to-be-removed automake
> hack.
> bsp_howto/Makefile.am:     Future automake versions will no longer place in
> the builddir
> bsp_howto/Makefile.am:     (rather than in the srcdir) the generated '.info'
> files that
> bsp_howto/Makefile.am:     appear to be cleaned, by e.g. being listed in
> CLEANFILES or
> bsp_howto/Makefile.am:     DISTCLEANFILES.
> bsp_howto/Makefile.am:     If you want your '.info' files to be placed in
> the builddir
> bsp_howto/Makefile.am:     rather than in the srcdir, you have to use the
> shiny new
> bsp_howto/Makefile.am:     'info-in-builddir' automake option.
> Am I going wrong somewhere?
> On Thu, Aug 6, 2015 at 4:05 AM, Sujay Raj <sujayraaj at gmail.com> wrote:
>> Hi,
>> 1. Your PC configuration is good, build time (especially for RSB) will be
>> fast.
>> 2. The RSB documentation (and most documentation for sis and pc386) work
>> and following it would lead to successful build. All the steps you performed
>> are okay ( you are on the right way )
>> 3. Next step would be to try and run some examples on the gdb sis
>> simulator.
>> Have a look at the :
>> https://devel.rtems.org/wiki/GSoC/GettingStarted
>> https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start
>> and run some sample applications, modify some codes to get a feel.
>> 4. About the platform you wish to use, it depends on what work you want to
>> do with RTEMS. RTEMS supports a lot of Boards and hardwares.
>> For example, I am working on the 'xilinx_zynq_a9_qemu'  bsp, on the arm
>> arch. It supports networking through the new network stack from
>> rtems-libbsd. rtems-libbsd also gives usb support ( though I have not worked
>> on usb, but its in active development ).
>> The simulator for sis doesn't support networking etc. So you need to take
>> such things into consideration. I use QEMU for simulation as it gives a lot
>> of options to make what I want to do, easier.
>> Then there is the pc386 bsp for the i386 arch, it works fine with the both
>> the old and new stacks, plus I somehow feel that using i386 is easier than
>> using ARM, the available amount of documentation about using pc386 is the
>> highest.
>> There are other arch or bsp people might be interested in like the
>> raspberry pi, but I don't have much idea about it, there might be better
>> people to guide you about that if you intend to go in that direction.
>> So, a possible direction for you :
>> 1. Test some applications, maybe on sis or pc386 to have some
>> understanding of RTEMS.
>> 2. Decide on something you want to work on and then choose a suitable arch
>> and bsp for it. ( This will depend on you experience, but once you decide
>> the work, you can ask for suggestions. People are very helpful here).
>> Have a look at :
>> https://devel.rtems.org/wiki/Developer/OpenProjects
>> and
>> https://devel.rtems.org/wiki/Developer/SmallProjects
>> for ideas on how you can contribute.
>> Thanks and Regards,
>> Sujay Raj
>> On Thu, Aug 6, 2015 at 9:37 AM, Sarvesh Patkar <sarveshspatkar at gmail.com>
>> wrote:
>>> Hi all,
>>> I am a beginner. I am running Ubuntu 14.04 on Oracle VM VirtualBox on
>>> Windows PC. My host PC has the following configuration. Processor= Core i5,
>>> RAM=16GB, Hard disk size= 1TB.
>>> I wanted to know what platform should I use for learning and developing
>>> RTEMS.
>>> Also, I installed RSB according to this link https://docs.rtems.org/rsb/
>>> but I am trying to figure out what platform to use.
>>> I have roughly used the following commands to install RSB and download
>>> RTEMS. I would like to know how to proceed further and whether I was roughly
>>> on the right way.
>>> cd
>>> mkdir -p development/rtems/src
>>> cd development/rtems/src
>>> sudo apt-get install git
>>> git clone git://git.rtems.org/rtems-source-builder.git
>>> cd rtems-source-builder
>>> sudo apt-get install bison cvs g++ texinfo flex
>>> sudo apt-get install build-essential vim zlib1g-dev libncurses5-dev
>>> python-dev
>>> source-builder/sb-check
>>> cd rtems
>>> ../source-builder/sb-set-builder --log=l-sparc.txt
>>> --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
>>> $HOME/development/rtems/4.11/bin/sparc-rtems4.11-gcc -v
>>> git clone git://git.rtems.org/rtems.git
>>> cd rtems
>>> export PATH=/development/rtems/4.11/bin:$PATH
>>> ./bootstrap
>>> cd ..
>>> mkdir b-sis
>>> cd b-sis
>>> ../rtems/configure --target=sparc-rtems4.11 --enable-rtremsbsp=sis
>>> --enable-tests=samples --disable-posix
>>> Thank you,
>>> Sarvesh Patkar
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
