Installation query
Nick Withers nick.withers at anu.edu.au
Fri Aug 7 02:33:26 UTC 2015
This isn't normal then?
I've been seeing the same thing for nigh on a year perhaps and not
worried about it (I thought the RTEMS automake infrastructure just
needed updating to follow automake changes), with RSB-built tools...?
On Thu, 2015-08-06 at 16:03 -0400, Gedare Bloom wrote:
> You need to build the autotools with RSB to ensure you get the correct
> version, and check they are picked up in your PATH.
> On Thu, Aug 6, 2015 at 3:14 PM, Sarvesh Patkar <sarveshspatkar at gmail.com> wrote:
> > Hi,
> > Thanks for the quick reply.
> > I tried the steps mentioned on the quickstart page. After downloading RTEMS,
> > when I try the bootstrap command, I get several warnings, which go as
> > follows.
> > Makefile.am:23: warning: source file 'timer/timer.c' is in a subdirectory,
> > Makefile.am:23: but option 'subdir-objects' is disabled
> > Makefile.am:23: warning: source file 'timer/timerisr.c' is in a
> > subdirectory,
> > Makefile.am:23: warning: source file 'shmsupp/addrconv.c' is in a
> > subdirectory,
> > Makefile.am:23: warning: source file 'shmsupp/getcfg.c' is in a
> > subdirectory,
> > Makefile.am:23: warning: source file 'shmsupp/lock.c' is in a subdirectory,
> > Makefile.am:23: warning: source file 'shmsupp/mpisr.c' is in a subdirectory,
> > ./c/src/lib/libbsp/no_cpu
> > acinclude.m4 is unchanged
> > ./c/src
> > ./c/src/ada-tests
> > mptests/mp01/node1/Makefile.am:9: warning: source file
> > '../../../support/init.c' is in a subdirectory,
> > mptests/mp01/node1/Makefile.am:9: but option 'subdir-objects' is disabled
> > automake: warning: possible forward-incompatibility.
> > automake: At least a source file is in a subdirectory, but the
> > 'subdir-objects'
> > automake: automake option hasn't been enabled.  For now, the corresponding
> > output
> > automake: object file(s) will be placed in the top-level directory.
> > However,
> > automake: this behaviour will change in future Automake versions: they will
> > automake: unconditionally cause object files to be placed in the same
> > subdirectory
> > automake: of the corresponding sources.
> > automake: You are advised to start using 'subdir-objects' option throughout
> > your
> > automake: project, to avoid future incompatibilities.
> > mptests/mp01/node2/Makefile.am:9: warning: source file
> > mptests/mp01/node2/Makefile.am:9: but option 'subdir-objects' is disabled
> > mptests/mp02/node1/Makefile.am:9: warning: source file
> > mptests/mp02/node1/Makefile.am:9: but option 'subdir-objects' is disabled
> > mptests/mp02/node2/Makefile.am:9: warning: source file
> > mptests/mp02/node2/Makefile.am:9: but option 'subdir-objects' is disabled
> > These warnings repeat themselves for a lot of source files in
> > subdirectories. I do not understand how to enable the subdir-objects option.
> > Also, at the very end I also get the following messages.
> > ada_user/Makefile.am: warning: Oops!
> > ada_user/Makefile.am:     It appears this file (or files included by it) are
> > triggering
> > ada_user/Makefile.am:     an undocumented, soon-to-be-removed automake hack.
> > ada_user/Makefile.am:     Future automake versions will no longer place in
> > the builddir
> > ada_user/Makefile.am:     (rather than in the srcdir) the generated '.info'
> > files that
> > ada_user/Makefile.am:     appear to be cleaned, by e.g. being listed in
> > CLEANFILES or
> > ada_user/Makefile.am:     DISTCLEANFILES.
> > ada_user/Makefile.am:     If you want your '.info' files to be placed in the
> > builddir
> > ada_user/Makefile.am:     rather than in the srcdir, you have to use the
> > shiny new
> > ada_user/Makefile.am:     'info-in-builddir' automake option.
> > bsp_howto/Makefile.am: warning: Oops!
> > bsp_howto/Makefile.am:     It appears this file (or files included by it)
> > are triggering
> > bsp_howto/Makefile.am:     an undocumented, soon-to-be-removed automake
> > hack.
> > bsp_howto/Makefile.am:     Future automake versions will no longer place in
> > the builddir
> > bsp_howto/Makefile.am:     (rather than in the srcdir) the generated '.info'
> > files that
> > bsp_howto/Makefile.am:     appear to be cleaned, by e.g. being listed in
> > CLEANFILES or
> > bsp_howto/Makefile.am:     DISTCLEANFILES.
> > bsp_howto/Makefile.am:     If you want your '.info' files to be placed in
> > the builddir
> > bsp_howto/Makefile.am:     rather than in the srcdir, you have to use the
> > shiny new
> > bsp_howto/Makefile.am:     'info-in-builddir' automake option.
> > Am I going wrong somewhere?
> > On Thu, Aug 6, 2015 at 4:05 AM, Sujay Raj <sujayraaj at gmail.com> wrote:
> >> Hi,
> >> 1. Your PC configuration is good, build time (especially for RSB) will be
> >> fast.
> >> 2. The RSB documentation (and most documentation for sis and pc386) work
> >> and following it would lead to successful build. All the steps you performed
> >> are okay ( you are on the right way )
> >> 3. Next step would be to try and run some examples on the gdb sis
> >> simulator.
> >> Have a look at the :
> >> https://devel.rtems.org/wiki/GSoC/GettingStarted
> >> https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start
> >> and run some sample applications, modify some codes to get a feel.
> >> 4. About the platform you wish to use, it depends on what work you want to
> >> do with RTEMS. RTEMS supports a lot of Boards and hardwares.
> >> For example, I am working on the 'xilinx_zynq_a9_qemu'  bsp, on the arm
> >> arch. It supports networking through the new network stack from
> >> rtems-libbsd. rtems-libbsd also gives usb support ( though I have not worked
> >> on usb, but its in active development ).
> >> The simulator for sis doesn't support networking etc. So you need to take
> >> such things into consideration. I use QEMU for simulation as it gives a lot
> >> of options to make what I want to do, easier.
> >> Then there is the pc386 bsp for the i386 arch, it works fine with the both
> >> the old and new stacks, plus I somehow feel that using i386 is easier than
> >> using ARM, the available amount of documentation about using pc386 is the
> >> highest.
> >> There are other arch or bsp people might be interested in like the
> >> raspberry pi, but I don't have much idea about it, there might be better
> >> people to guide you about that if you intend to go in that direction.
> >> So, a possible direction for you :
> >> 1. Test some applications, maybe on sis or pc386 to have some
> >> understanding of RTEMS.
> >> 2. Decide on something you want to work on and then choose a suitable arch
> >> and bsp for it. ( This will depend on you experience, but once you decide
> >> the work, you can ask for suggestions. People are very helpful here).
> >> Have a look at :
> >> https://devel.rtems.org/wiki/Developer/OpenProjects
> >> and
> >> https://devel.rtems.org/wiki/Developer/SmallProjects
> >> for ideas on how you can contribute.
> >> Thanks and Regards,
> >> Sujay Raj
> >> On Thu, Aug 6, 2015 at 9:37 AM, Sarvesh Patkar <sarveshspatkar at gmail.com>
> >> wrote:
> >>> Hi all,
> >>> I am a beginner. I am running Ubuntu 14.04 on Oracle VM VirtualBox on
> >>> Windows PC. My host PC has the following configuration. Processor= Core i5,
> >>> RAM=16GB, Hard disk size= 1TB.
> >>> I wanted to know what platform should I use for learning and developing
> >>> RTEMS.
> >>> Also, I installed RSB according to this link https://docs.rtems.org/rsb/
> >>> but I am trying to figure out what platform to use.
> >>> I have roughly used the following commands to install RSB and download
> >>> RTEMS. I would like to know how to proceed further and whether I was roughly
> >>> on the right way.
> >>> cd
> >>> mkdir -p development/rtems/src
> >>> cd development/rtems/src
> >>> sudo apt-get install git
> >>> git clone git://git.rtems.org/rtems-source-builder.git
> >>> cd rtems-source-builder
> >>> sudo apt-get install bison cvs g++ texinfo flex
> >>> sudo apt-get install build-essential vim zlib1g-dev libncurses5-dev
> >>> python-dev
> >>> source-builder/sb-check
> >>> cd rtems
> >>> ../source-builder/sb-set-builder --log=l-sparc.txt
> >>> --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
> >>> $HOME/development/rtems/4.11/bin/sparc-rtems4.11-gcc -v
> >>> git clone git://git.rtems.org/rtems.git
> >>> cd rtems
> >>> export PATH=/development/rtems/4.11/bin:$PATH
> >>> ./bootstrap
> >>> cd ..
> >>> mkdir b-sis
> >>> cd b-sis
> >>> ../rtems/configure --target=sparc-rtems4.11 --enable-rtremsbsp=sis
> >>> --enable-tests=samples --disable-posix
> >>> Thank you,
> >>> Sarvesh Patkar
> >>> _______________________________________________
> >>> users mailing list
> >>> users at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
> users mailing list
> users at rtems.org
