Installation query
Fri Aug 7 15:51:16 UTC 2015
On 8/7/2015 10:41 AM, Gedare Bloom wrote:
> P.S. the error appears to be in building the "edison" BSP, but we need
> a bit more of the log (Back to the "Error" message) to know why it
> stopped working. It got to make install, so that means your build
> probably succeeded, there was just some issue late in the build.
Because of the typo, he built all i386 bsps. It is possible he ran out
of disk space. That isn't uncommon especially on a VM.
FWIW I just built edison with all tests and it finished successfully.
../rtems/configure --target=i386-rtems4.11 --prefix=/home/joel/rtems-4.11-work/bsp-install/ --disable-multiprocessing --enable-cxx --disable-rdbg --enable-maintainer-mode --enable-tests --enable-networking --enable-posix --disable-itron --disable-deprecated --disable-ada --enable-expada --enable-rtemsbsp=edison
> On Fri, Aug 7, 2015 at 11:32 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 8/7/2015 9:33 AM, Sarvesh Patkar wrote:
>>> Hey guys,
>>> I am a newbie. So, I am having a lot of doubts and issues in understanding
>>> while installation. I deleted all that I had installed till yesterday and
>>> started over. I executed the following commands.
>>> mkdir -p development/rtems/src
>>> cd development/rtems/src
>>> git clone git://git.rtems.org/rtems-source-builder.git
>>> <http://git.rtems.org/rtems-source-builder.git>
>>> cd rtems-source-builder
>>> source-builder/sb-check
>>> cd rtems
>>> ../source-builder/sb-set-builder --log=l-pc386.txt
>>> --prefix=/home/sarvesh/development/rtems/4.11 4.11/rtems-i386
>>> /home/sarvesh/development/rtems/4.11/bin/i386-rtems4.11-gcc -v
>>> git clone git://git.rtems.org/rtems.git <http://git.rtems.org/rtems.git>
>>> cd rtems
>>> export PATH=/home/sarvesh/development/rtems/4.11/bin:$PATH
>>> ./bootstrap
>>> cd ..
>>> mkdir pc386
>>> mkdir pc386/install
>> Your install directory should not be under the build directory.
>> They should be separate.
>>> cd pc386
>>> ../rtems/configure --target=i386-rtems4.11 --enable-rtremsbsp=pc386
>>> --enable-tests=samples --disable-posix
>>> --prefix=/home/sarvesh/development/rtems/4.11/pc386/install
>> You spelled the option incorrectly. It is "--enable-rtemsbsp=pc386"
>> As a point of reference, I have this (more or less) as my tree structure.
>> ~/rtems-4.11-work
>>     tools
>>     bsp-install
>>     rtems
>>     b-pc386
>> There is no obligation or requirement to do it that way. All BSPs can be
>> installed into a single directory safely. And it could be the same as the
>> tools directory.
>> b-pc386 can be removed after the installation.
>>> make
>>> This is what happened at the very end of executing 'make'.
>>> Rest of it seemed all correct.
>>> Making all in edison
>>> make[2]: Entering directory
>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c/edison'
>>> make[2]: *** No rule to make target `all'.  Stop.
>>> make[2]: Leaving directory
>>> make[1]: *** [all-recursive] Error 1
>>> make[1]: Leaving directory
>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
>>> make: *** [all-recursive] Error 1
>>> I also tried running the next command according to the Quick Start page
>>> sudo PATH=/home/sarvesh/development/rtems/4.11/bin:${PATH} make install
>>> This is what followed.
>>> Making install in tools/build
>>> make[1]: Entering directory
>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
>>>    /bin/mkdir -p '/home/sarvesh/development/rtems/4.11/pc386/install/bin'
>>>     /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c
>>>    /usr/bin/install -c install-if-change
>>> make[2]: Nothing to be done for `install-data-am'.
>>> Making install in tools/cpu
>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
>>> Making install in generic
>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
>>> make[3]: Entering directory
>>> make[3]: Nothing to be done for `install-exec-am'.
>>> make[3]: Nothing to be done for `install-data-am'.
>>> make[3]: Leaving directory
>>> Making install in testsuites/tools
>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
>>>    /usr/bin/install -c difftest
>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-difftest'
>>>    /usr/bin/install -c sorttimes
>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-sorttimes'
>>> Making install in i386-rtems4.11/c
>>> Making install in .
>>> *Making install in edison
>>> make[2]: *** No rule to make target `install'.  Stop.
>>> make[1]: *** [install-recursive] Error 1
>>> make: *** [install-recursive] Error 1
>>> Can you please help me understand why this may be happening and how it can
>>> be overcome?
>>> Thank you,
>>> Sarvesh Patkar
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> users mailing list
>> users at rtems.org
