Installation query
Donald H Locker dhlocker at comcast.net
Fri Aug 7 16:40:45 UTC 2015
Thank you for this, Joel. Can you please clarify the directory structure?
My understanding is that the non-prefixed directories are sub-dirs of the first, i.e. the structure is:
    ~/rtems-4.11-work
    ~/rtems-4.11-work/tools
    ~/rtems-4.11-work/bsp-install
    ~/rtems-4.11-work/rtems
    ~/rtems-4.11-work/b-pc386
Is this a correct interpretation?
Thank you again,
Donald.
----- Original Message -----
> From: "Joel Sherrill" <joel.sherrill at oarcorp.com>
> To: "Sarvesh Patkar" <sarveshspatkar at gmail.com>, users at rtems.org
> Sent: Friday, August 7, 2015 11:32:56 AM
> Subject: Re: Installation query
> On 8/7/2015 9:33 AM, Sarvesh Patkar wrote:
> > Hey guys,
> > I am a newbie. So, I am having a lot of doubts and issues in understanding
> > while installation. I deleted all that I had installed till yesterday and
> > started over. I executed the following commands.
> > mkdir -p development/rtems/src
> > cd development/rtems/src
> > git clone git://git.rtems.org/rtems-source-builder.git
> > <http://git.rtems.org/rtems-source-builder.git>
> > cd rtems-source-builder
> > source-builder/sb-check
> > cd rtems
> > ../source-builder/sb-set-builder --log=l-pc386.txt
> > --prefix=/home/sarvesh/development/rtems/4.11 4.11/rtems-i386
> > /home/sarvesh/development/rtems/4.11/bin/i386-rtems4.11-gcc -v
> > git clone git://git.rtems.org/rtems.git <http://git.rtems.org/rtems.git>
> > cd rtems
> > export PATH=/home/sarvesh/development/rtems/4.11/bin:$PATH
> > ./bootstrap
> > cd ..
> > mkdir pc386
> > mkdir pc386/install
> Your install directory should not be under the build directory.
> They should be separate.
> > cd pc386
> > ../rtems/configure --target=i386-rtems4.11 --enable-rtremsbsp=pc386
> > --enable-tests=samples --disable-posix
> > --prefix=/home/sarvesh/development/rtems/4.11/pc386/install
> You spelled the option incorrectly. It is "--enable-rtemsbsp=pc386"
> As a point of reference, I have this (more or less) as my tree structure.
> ~/rtems-4.11-work
>     tools
>     bsp-install
>     rtems
>     b-pc386
> There is no obligation or requirement to do it that way. All BSPs can be
> installed into a single directory safely. And it could be the same as the
> tools directory.
> b-pc386 can be removed after the installation.
> > make
> > This is what happened at the very end of executing 'make'.
> > Rest of it seemed all correct.
> > Making all in edison
> > make[2]: Entering directory
> > `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c/edison'
> > make[2]: *** No rule to make target `all'.  Stop.
> > make[2]: Leaving directory
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory
> > `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
> > make: *** [all-recursive] Error 1
> > I also tried running the next command according to the Quick Start page
> > sudo PATH=/home/sarvesh/development/rtems/4.11/bin:${PATH} make install
> > This is what followed.
> > Making install in tools/build
> > make[1]: Entering directory
> > `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
> >   /bin/mkdir -p '/home/sarvesh/development/rtems/4.11/pc386/install/bin'
> >    /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c
> >   /usr/bin/install -c install-if-change
> > make[2]: Nothing to be done for `install-data-am'.
> > Making install in tools/cpu
> > `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
> > Making install in generic
> > `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
> > make[3]: Entering directory
> > make[3]: Nothing to be done for `install-exec-am'.
> > make[3]: Nothing to be done for `install-data-am'.
> > make[3]: Leaving directory
> > Making install in testsuites/tools
> > `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
> > `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
> >   /usr/bin/install -c difftest
> >   '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-difftest'
> >   /usr/bin/install -c sorttimes
> >   '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-sorttimes'
> > Making install in i386-rtems4.11/c
> > Making install in .
> > *Making install in edison
> > make[2]: *** No rule to make target `install'.  Stop.
> > make[1]: *** [install-recursive] Error 1
> > make: *** [install-recursive] Error 1
> > Can you please help me understand why this may be happening and how it can
> > be overcome?
> > Thank you,
> > Sarvesh Patkar
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> users mailing list
> users at rtems.org
