bbb rtems build fail.
Angelo Fraietta newsgroups at smartcontroller.com.au
Sun Aug 23 23:16:55 UTC 2015
These are the instructions I am using if they are of any help to you
On Mon, Aug 24, 2015 at 9:14 AM, Chris Johns <chrisj at rtems.org> wrote:
> Hi and welcome,
> The devel at rtems.org list is for the development of RTEMS so I have moved
> the question to the user list which is more appropriate.
> On 21/08/2015 4:19 pm, Hardik Patel wrote:
> > Hello Everyone...My name is hardik patel. I have started work on BSP
> > improvement of RTEMS for beaglebone black. After Building RSB , When I
> > am building RTEMS using make i face error...please help me..thanks you
> What host platform are you using and what is the configure command line ?
> Did you bootstrap the source after you cloned the repository ?
> Chris
> > Making all in arm-rtems4.11/c
> > make[1]: Entering directory
> > `/home/hardik/development/rtems/b-beagle/arm-rtems4.11/c'
> > Making all in .
> > make[2]: Entering directory
> > make[2]: Nothing to be done for `all-am'.
> > make[2]: Leaving directory
> > Making all in beagleboneblack
> > `/home/hardik/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
> > make[2]: *** No rule to make target `all'.  Stop.
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory
> > make: *** [all-recursive] Error 1
> > devel mailing list
> > devel at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150824/c5cd05e5/attachment-0002.html>
Type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20150824/c5cd05e5/attachment-0002.bin>
