Zynq Ethernet driver
Davide Viti zinosat at tiscali.it
Tue Dec 1 10:30:38 UTC 2015
Hi all,
I managed to build libbsd and tried to run some of the included tests.
I'm running the tests tests both for xilinx_zynq_zedboard (on the Microzed)
and xilinx_a9_qemu
I'm currently focused on dhcpd01.exe:
 * If I run the test on qemu, with TAP interface, everything works fine: I
get an address from the DHCP server and I can ping the (virtual) board (see
[1])
 * if I run it on real hardware, I can see the negotiation with wireshark,
I cannot ping the board
Looks like the board never sets the IP address on the device (see [2]): I
cannot see "devctl: !system=IFNET subsystem=cgem0 type=LINK_UP" like on the
simulator
can I get some help on this?
It is not relevant to this particular networking problem, bu the test
crashes if I do not comment out the definition of DEFAULT_NETWORK_SHELL: on
the simulator the shell works
thank you in advance
Davide
[1] http://pastebin.com/UZ21rgqn
[2] http://pastebin.com/jJhMH0wN
2015-11-25 14:09 GMT+01:00 Davide Viti <zinosat at tiscali.it>:
> Hi Sebastian,
> thank you so much for letting me know: will try that
> regards,
> Davide
> 2015-11-25 12:50 GMT+01:00 Sebastian Huber <
> sebastian.huber at embedded-brains.de>:
>> The network driver for the Zynq platform is included in the libbsd:
>> https://git.rtems.org/rtems-libbsd/
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20151201/584a4116/attachment.html>
