Unable to build sparc toolset
Nick Withers nick.withers at anu.edu.au
Mon Dec 7 09:55:04 UTC 2015
Hi Sambeet,
On Mon, 2015-12-07 at 13:53 +0530, Sambeet Panigrahi wrote:
> I am a newbie trying to install the sparc toolset.I followed all the
> steps
> from the documentation in the site
> https://docs.rtems.org/rsb
> On the terminal in the directory
> /development/rtems/src/rtems-source-builder/rtems
> I typed
> $ ../source-builder/sb-set-builder -
> -prefix=$HOME/development/rtems/4.11
> 4.11/rtems-sparc to install sparc as mentioned in the documentation
> but I
> get the following error everytime
> RTEMS Source Builder - Set Builder, 4.11.0 (47d703fd8c95 modified)
> Build Set: 4.11/rtems-sparc
> Build Set: 4.11/rtems-autotools.bset
> Build Set: 4.11/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> package: autoconf-2.69-x86_64-linux-gnu-1
> download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz ->
> sources/autoconf-2.69.tar.gz
> download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: error:
> <urlopen error ftp error: [Errno 110] Connection timed out>
> error: downloading
> ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: all
> paths have failed, giving up
> Build FAILED
>   See error report: rsb-report-autoconf-2.69-x86_64-linux-gnu-1.txt
> error: downloading
> Build Set: Time 0:02:09.693545
> error: downloading
> Build Set: Time 0:02:09.695649
> error: downloading
> Build Set: Time 0:02:09.713884
> Build FAILED
> I tried to manually download the tools from
> ftp://ftp.gnu.org
> but even that is not opening in the browser
> I have been into problems before because of my institute firewall, is
> it
> happening because of that? Can somebody please help me?
If you can't even view ftp://ftp.gnu.org then yes, I'd say it is.
Does this work for you? http://ftp.gnu.org/gnu/autoconf/
> users mailing list
> users at rtems.org
