Unable to build sparc toolset
Joel Sherrill
joel at rtems.org
Mon Dec 7 15:32:55 UTC 2015
On Mon, Dec 7, 2015 at 3:55 AM, Nick Withers <nick.withers at anu.edu.au>
wrote:
> Hi Sambeet,
> On Mon, 2015-12-07 at 13:53 +0530, Sambeet Panigrahi wrote:
> > I am a newbie trying to install the sparc toolset.I followed all the
> > steps
> > from the documentation in the site
> > https://docs.rtems.org/rsb
> > On the terminal in the directory
> > /development/rtems/src/rtems-source-builder/rtems
> > I typed
> > $ ../source-builder/sb-set-builder -
> > -prefix=$HOME/development/rtems/4.11
> > 4.11/rtems-sparc to install sparc as mentioned in the documentation
> > but I
> > get the following error everytime
> > RTEMS Source Builder - Set Builder, 4.11.0 (47d703fd8c95 modified)
> > Build Set: 4.11/rtems-sparc
> > Build Set: 4.11/rtems-autotools.bset
> > Build Set: 4.11/rtems-autotools-internal.bset
> > config: tools/rtems-autoconf-2.69-1.cfg
> > package: autoconf-2.69-x86_64-linux-gnu-1
> > download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz ->
> > sources/autoconf-2.69.tar.gz
> > download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: error:
> > <urlopen error ftp error: [Errno 110] Connection timed out>
> > error: downloading
> > ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: all
> > paths have failed, giving up
> > Build FAILED
> > See error report: rsb-report-autoconf-2.69-x86_64-linux-gnu-1.txt
> > error: downloading
> > Build Set: Time 0:02:09.693545
> > error: downloading
> > Build Set: Time 0:02:09.695649
> > error: downloading
> > Build Set: Time 0:02:09.713884
> > Build FAILED
> > I tried to manually download the tools from
> > ftp://ftp.gnu.org
> > but even that is not opening in the browser
> > I have been into problems before because of my institute firewall, is
> > it
> > happening because of that? Can somebody please help me?
> If you can't even view ftp://ftp.gnu.org then yes, I'd say it is.
> Does this work for you? http://ftp.gnu.org/gnu/autoconf/
Nick.. good idea. I wonder if we should ask Chris to use http not ftp
when it is available. Lots of firewalls block ftp.
Sambeet.. if you manually download the source tarballs into the
sources/ subdirectory under rtems-source-builder/rtems, then
it won't try the ftp link.
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20151207/9d147a47/attachment.html>
