Unable to build sparc toolset
    Nick Withers
    nick.withers at anu.edu.au
    Tue Dec  8 22:48:06 UTC 2015
On Tue, 2015-12-08 at 10:48 -0500, Gedare Bloom wrote:
> And if you want to kill it, I would send a kill signal to the process
As Gedare's alluding to, the Ctrl-Z is probably a problem here... It'll
typically suspend a process, so it's still running.
Ctrl-C to kill :-)
> On Tue, Dec 8, 2015 at 8:09 AM, Sambeet Panigrahi
> <sambeet161616 at gmail.com> wrote:
> > > Hi Sambeet,
> > > If you can't even view ftp://ftp.gnu.org then yes, I'd say it is.
> > > Does this work for you? http://ftp.gnu.org/gnu/autoconf/
> >  Thank you Nick for the help.It works and I went on replacing
> > several more
> > files required in building rtems by manually downloading them from
> > the http
> > link.It was working fine but then in
> >            building: sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu
> > -1
> > It took a lot of time about 30 minutes.It was then that i
> > terminated the
> > process using ctrl +Z.From then on whenever i am rebuilding,I get
> > this error
> > error: copying tree:
> > /home/sambeet/development/rtems/src/rtems-source
> > -builder/rtems/build/tmp/sparc-rtems4.11-binutils-2.24-x86_64-linux
> > -gnu-1-root-sambeet/home/sambeet/development/rtems/4.11/bin/sparc
> > -rtems4.11-as
> > -builder/rtems/build/tmp/sb-sambeet/4.11/rtems
> > -sparc/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as:
> > [Errno 26] Text file busy:
> > '/home/sambeet/development/rtems/src/rtems-source
> > -sparc/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as'
> > Build Set: Time 0:05:49.468578
> > Build FAILED
> > Can you please help me
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
