Unable to build sparc toolset
    Gedare Bloom
    gedare at rtems.org
    Tue Dec  8 15:48:13 UTC 2015
i'm not sure if there is a "--clean" option in RSB. try force-deleting
rtems-source-builder/rtems/build and try again. it seems ctrl-z caused
something to hang. you should instead peer into the log file (tail
l-sparc.txt) to see what the build is up to. And if you want to kill
it, I would send a kill signal to the process
On Tue, Dec 8, 2015 at 8:09 AM, Sambeet Panigrahi
<sambeet161616 at gmail.com> wrote:
>>Hi Sambeet,
>>If you can't even view ftp://ftp.gnu.org then yes, I'd say it is.
>>Does this work for you? http://ftp.gnu.org/gnu/autoconf/
>  Thank you Nick for the help.It works and I went on replacing several more
> files required in building rtems by manually downloading them from the http
> link.It was working fine but then in
>            building: sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1
> It took a lot of time about 30 minutes.It was then that i terminated the
> process using ctrl +Z.From then on whenever i am rebuilding,I get this error
> error: copying tree:
> /home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1-root-sambeet/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as
> /home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as:
> [Errno 26] Text file busy:
> '/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as'
> Build Set: Time 0:05:49.468578
> Build FAILED
> Can you please help me
> users mailing list
> users at rtems.org
