Unable to build sparc toolset
Sambeet Panigrahi
sambeet161616 at gmail.com
Thu Dec 10 06:37:46 UTC 2015
>1. Find rtems/config/tools/rtems-tools-1.cfg
>2. Change lines 23 to 33 to (the following is a single line):
> %source set rtems-tools >https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz <https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz>
>Let me know how that goes.
>Chris
Hey chris,
I made the changes as told
%if %{rtems_tools_build}
and the output from terminal is as follows
error: rtems-tools-git-1.cfg:7: macro '%{rtems_tools_version}' not found
warning: switched to dry run due to errors
error: rtems-tools-git-1.cfg:8: macro '%{rtems_tools_version}' not found
error: rtems-tools-git-1.cfg:9: macro '%{rtems_tools_version}' not found
error: rtems-tools-git-1.cfg:12: macro '%{rtems_tools_version}' not found
error: rtems-tools-git-1.cfg:23: macro '%{rtems_tools_version}' not found
error: rtems-tools-git-1.cfg:24: macro '%{rtems_tools_version}' not found
error: rtems-tools-4.11-1.cfg:0: macro '%{rtems_tools_version}' not found
package: rtems-tools-%{rtems_tools_version}-1
download:
-> sources/rtems-tools-4.11.0-rc1.tar.xz
See error report: rsb-report-rtems-tools-%{rtems_tools_version}-1.txt
reporting: tools/rtems-tools-4.11-1.cfg ->
rtems-tools-%{rtems_tools_version}-1.xml
config: tools/rtems-kernel-4.11.cfg
installing: expat-2.1.0-x86_64-linux-gnu-1 ->
/home/sambeet/development/rtems/4.11
installing: sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1 ->
installing:
sparc-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1 ->
installing: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1 ->
installing: rtems-tools-%{rtems_tools_version}-1 ->
cleaning: expat-2.1.0-x86_64-linux-gnu-1
cleaning: sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1
cleaning: sparc-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1
cleaning: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
cleaning: rtems-tools-%{rtems_tools_version}-1
Build Set: Time 1:21:54.065104
I am not able to understand the error now.Can you please help?
On Thu, Dec 10, 2015 at 8:39 AM, Sambeet Panigrahi <sambeet161616 at gmail.com>
wrote:
> >RSB always assumes it should restart fresh. Ithink there may be an
> option not to restart/download, and it will look for the sources in the
> >current directory, but I could be mistaken. Another more complicated
> option would be to copy and modify the .cfg files in RSB to either >point
> them to downloadable files or to an internal git clone url.
> Hey Gedare.
> Can you please suggest steps for doing one of the above solutions to my
> problem i.e directing RSB to look for local contents or modifying .cfg
> files?
> Thank you.
URL: <http://lists.rtems.org/pipermail/users/attachments/20151210/5fef3a92/attachment-0001.html>
