Unable to build sparc toolset
Sambeet Panigrahi
sambeet161616 at gmail.com
Thu Dec 10 06:43:10 UTC 2015
Attatched with the mail is the error report
On Thu, Dec 10, 2015 at 12:07 PM, Sambeet Panigrahi <sambeet161616 at gmail.com
> wrote:
> >1. Find rtems/config/tools/rtems-tools-1.cfg
> >2. Change lines 23 to 33 to (the following is a single line):
> > %source set rtems-tools >https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz <https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz>
> >Let me know how that goes.
> >Chris
> Hey chris,
> I made the changes as told
> %if %{rtems_tools_build}
> and the output from terminal is as follows
> error: rtems-tools-git-1.cfg:7: macro '%{rtems_tools_version}' not found
> warning: switched to dry run due to errors
> error: rtems-tools-git-1.cfg:8: macro '%{rtems_tools_version}' not found
> error: rtems-tools-git-1.cfg:9: macro '%{rtems_tools_version}' not found
> error: rtems-tools-git-1.cfg:12: macro '%{rtems_tools_version}' not found
> error: rtems-tools-git-1.cfg:23: macro '%{rtems_tools_version}' not found
> error: rtems-tools-git-1.cfg:24: macro '%{rtems_tools_version}' not found
> error: rtems-tools-4.11-1.cfg:0: macro '%{rtems_tools_version}' not found
> package: rtems-tools-%{rtems_tools_version}-1
> download:
> -> sources/rtems-tools-4.11.0-rc1.tar.xz
> See error report: rsb-report-rtems-tools-%{rtems_tools_version}-1.txt
> reporting: tools/rtems-tools-4.11-1.cfg ->
> rtems-tools-%{rtems_tools_version}-1.xml
> config: tools/rtems-kernel-4.11.cfg
> installing: expat-2.1.0-x86_64-linux-gnu-1 ->
> /home/sambeet/development/rtems/4.11
> installing: sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1 ->
> installing:
> sparc-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1 ->
> installing: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1 ->
> installing: rtems-tools-%{rtems_tools_version}-1 ->
> cleaning: expat-2.1.0-x86_64-linux-gnu-1
> cleaning: sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1
> cleaning:
> cleaning: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
> cleaning: rtems-tools-%{rtems_tools_version}-1
> Build Set: Time 1:21:54.065104
> I am not able to understand the error now.Can you please help?
> On Thu, Dec 10, 2015 at 8:39 AM, Sambeet Panigrahi <
> sambeet161616 at gmail.com> wrote:
>> >RSB always assumes it should restart fresh. Ithink there may be an
>> option not to restart/download, and it will look for the sources in the
>> >current directory, but I could be mistaken. Another more complicated
>> option would be to copy and modify the .cfg files in RSB to either >point
>> them to downloadable files or to an internal git clone url.
>> Hey Gedare.
>> Can you please suggest steps for doing one of the above solutions to my
>> problem i.e directing RSB to look for local contents or modifying .cfg
>> files?
>> Thank you.
URL: <http://lists.rtems.org/pipermail/users/attachments/20151210/a784843b/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: dry run (no actual error)
Command Line: ../source-builder/sb-set-builder --prefix=/home/sambeet/development/rtems/4.11 4.11/rtems-sparc
Python: 2.7.6 (default, Jun 22 2015, 17:58:13) [GCC 4.8.2]
https://github.com/RTEMS/rtems-source-builder.git/origin/47d703fd8c952f9a684a0a41faad81f5983acaaf-modified
Linux Holmes 3.13.0-37-generic #64-Ubuntu SMP Mon Sep 22 21:28:38 UTC 2014 x86_64
Tail of the build log:
==> %clean:
+ echo ==> %clean:
copy: /home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-sambeet => /home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc
reporting: tools/rtems-gdb-7.9-1.cfg -> sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.txt
making dir: /home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-sambeet/home/sambeet/development/rtems/4.11/share/rtems/rsb
reporting: tools/rtems-gdb-7.9-1.cfg -> sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.xml
config: tools/rtems-tools-4.11-1.cfg
script: 1: #!/bin/sh
script: 2: # ___build_pre in as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/sambeet/development/rtems/4.11"
script: 7: SB_PREFIX_CLEAN=$(echo "/home/sambeet/development/rtems/4.11" | /bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/sources"
script: 9: SB_BUILD_DIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-%{rtems_tools_version}-1"
script: 10: # host == build, use build; host != build , host uses host and build uses build
script: 11: SB_HOST_CFLAGS="-O2 -pipe "
script: 12: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 13: SB_HOST_LDFLAGS="-L/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 14: SB_BUILD_CFLAGS="-O2 -pipe -I/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 15: SB_BUILD_CXXFLAGS="-O2 -pipe -I/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_LDFLAGS="-L/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 17: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 18: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 19: SB_ARCH="x86_64"
script: 20: SB_OS="linux"
script: 21: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 22: export SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 23: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 24: export SB_CFLAGS SB_CXXFLAGS
script: 25: # Documentation
script: 26: SB_DOC_DIR="/home/sambeet/development/rtems/4.11/share/doc"
script: 27: export SB_DOC_DIR
script: 28: # Packages
script: 29: SB_PACKAGE_NAME="rtems-tools-%{rtems_tools_version}-1"
script: 30: SB_PACKAGE_BUILDNAME="rtems-tools-%{rtems_tools_version}-1"
script: 31: SB_PACKAGE_VERSION="%{rtems_tools_version}"
script: 32: SB_PACKAGE_RELEASE="1"
script: 33: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 34: # Build directories
script: 35: export SB_PREFIX
script: 36: SB_BUILD_DIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-%{rtems_tools_version}-1"
script: 37: SB_BUILD_ROOT="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-%{rtems_tools_version}-1-root-sambeet"
script: 38: SB_BUILD_ROOT_BINDIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-%{rtems_tools_version}-1-root-sambeet/${SB_PREFIX_CLEAN}/bin"
script: 39: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 40: SB_BUILD_CXC_DIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-%{rtems_tools_version}-1-cxc"
script: 41: SB_BUILD_CXC_ROOT="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-%{rtems_tools_version}-1-sambeet-cxc"
script: 42: SB_BUILD_CXC_ROOT_BINDIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-%{rtems_tools_version}-1-sambeet-cxc/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 44: SB_TMPROOT="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc"
script: 45: SB_TMPPREFIX="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 46: SB_TMPBINDIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 48: SB_TMPCXCROOT="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc"
script: 49: SB_TMPCXCPREFIX="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet-cxc/4.11/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 50: SB_TMPCXCBINDIR="/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet-cxc/4.11/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 52: # Extra path support
script: 53: SB_EXTRAPATH="/home/sambeet/development/rtems/src/rtems-source-builder/source-builder"
script: 54: # The compiler flags
script: 55:
script: 56:
script: 57: export CFLAGS_FOR_TARGET
script: 58: export CXXFLAGS_FOR_TARGET
script: 59: # Set up the path. Put the CXC path first.
script: 60: if test -n "${SB_TMPBINDIR}" ; then
script: 61: PATH="${SB_TMPBINDIR}:$PATH"
script: 62: fi
script: 63: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 64: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 65: fi
script: 66: if test -n "${SB_EXTRAPATH}" ; then
script: 67: PATH="${SB_EXTRAPATH}:$PATH"
script: 68: fi
script: 69:
script: 70:
script: 71: export PATH
script: 72: # Default environment set up.
script: 73: LANG=C
script: 74: export LANG
script: 75: unset DISPLAY || :
script: 76: umask 022
script: 77: cd "/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-%{rtems_tools_version}-1"
script: 78: echo "=> rtems-tools-%{rtems_tools_version}-1:"
script: 79: echo "==> %prep:"
script: 80: build_top=$(pwd)
script: 81: source_dir_rtems_tools="rtems-tools-%{rtems_tools_version}-1"
source setup: rtems-tools-%{rtems_tools_version}-1: source rtems-tools -q -D -n rtems-tools-%{rtems_tools_version}-1
making dir: /home/sambeet/development/rtems/src/rtems-source-builder/rtems/sources
download: https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz -> sources/rtems-tools-4.11.0-rc1.tar.xz
script: 82: cd /home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-%{rtems_tools_version}-1
script: 83: /usr/bin/xz -dc /home/sambeet/development/rtems/src/rtems-source-builder/rtems/sources/rtems-tools-4.11.0-rc1.tar.xz | /bin/tar -xvvf -
script: 84: cd rtems-tools-%{rtems_tools_version}-1
script: 85: /bin/chmod -R a+rX,g-w,o-w .
script: 86: cd ${build_top}
script: 87: SB_CXC="no"
script: 88: echo "==> clean %{buildroot}: ${SB_BUILD_ROOT}"
script: 89: /bin/rm -rf ${SB_BUILD_ROOT}
script: 90: /bin/mkdir -p ${SB_BUILD_ROOT}
script: 91: echo "==> %build:"
script: 92: build_top=$(pwd)
script: 93: if test "x86_64-linux-gnu" != "x86_64-linux-gnu" ; then
script: 94: RT_HOST="-host=x86_64-linux-gnu"
script: 95: else
script: 96: RT_HOST=
script: 97: fi
script: 98: cd ${source_dir_rtems_tools}
script: 99: ./waf configure ${RT_HOST} --prefix=/home/sambeet/development/rtems/4.11
script:100: ./waf
script:101: cd ${build_top}
script:102: echo "==> %install:"
script:103: build_top=$(pwd)
script:104: /bin/rm -rf $SB_BUILD_ROOT
script:105: cd ${source_dir_rtems_tools}
script:106: ./waf --destdir=$SB_BUILD_ROOT install
script:107: cd ${build_top}
script:108: echo "==> %clean:"
