How to build SMP RTEMS?
Molock, Dwaine S. (GSFC-5820) dwaine.s.molock at nasa.gov
Mon Dec 14 17:22:00 UTC 2015
On Dec 12, 2015, at 3:40 PM, Sebastian Huber <sebastian.huber at embedded-brains.de>
 wrote:
> ----- Am 12. Dez 2015 um 20:04 schrieb Molock, Dwaine S. (GSFC-5820) dwaine.s.molock at nasa.gov:
>> Hi,
>> I'm looking for documentation on how to build the SMP version of RTEMS?
> Use --enable-smp for your configure command line.  We have an SMP chapter in the user manual.  Unfortunately, the automatic documentation generation doesn't work currently, so better build the docs from the sources.
Where can I find instructions on how to manually build the documentation from source code?
>> Do I need to rebuild just the RTEMS kernel or the tools also?
> Only the BSP, which one do you intend to use? SMP is work in progress.
I'm currently using the sparc/LEON3 BSP but I would also like to build it for multi-core intel and arm processors.
