How to build SMP RTEMS?
Tue Dec 15 07:10:51 UTC 2015
On 14/12/15 18:22, Molock, Dwaine S. (GSFC-5820) wrote:
> On Dec 12, 2015, at 3:40 PM, Sebastian Huber <sebastian.huber at embedded-brains.de>
>   wrote:
>> ----- Am 12. Dez 2015 um 20:04 schrieb Molock, Dwaine S. (GSFC-5820) dwaine.s.molock at nasa.gov:
>>> Hi,
>>> I'm looking for documentation on how to build the SMP version of RTEMS?
>> Use --enable-smp for your configure command line.  We have an SMP chapter in the user manual.  Unfortunately, the automatic documentation generation doesn't work currently, so better build the docs from the sources.
> Where can I find instructions on how to manually build the documentation from source code?
It seems that this is nowhere documented. I use this
cd doc
mkdir b-doc
cd b-doc
../configure --enable-maintainer-mode
make
>>> Do I need to rebuild just the RTEMS kernel or the tools also?
>> Only the BSP, which one do you intend to use? SMP is work in progress.
> I'm currently using the sparc/LEON3 BSP but I would also like to build it for multi-core intel and arm processors.
x86 is currently not supported, see
https://devel.rtems.org/ticket/2183
In case you are interested in RTEMS SMP on x86 and you have some spare
budget, please contact Joel Sherill.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
