How to build SMP RTEMS?
Tue Dec 15 16:52:37 UTC 2015
On Tue, Dec 15, 2015 at 2:10 AM, Sebastian Huber
> On 14/12/15 18:22, Molock, Dwaine S. (GSFC-5820) wrote:
>> On Dec 12, 2015, at 3:40 PM, Sebastian Huber
>>   wrote:
>>> ----- Am 12. Dez 2015 um 20:04 schrieb Molock, Dwaine S. (GSFC-5820)
>>> dwaine.s.molock at nasa.gov:
>>>> Hi,
>>>> I'm looking for documentation on how to build the SMP version of RTEMS?
>>> Use --enable-smp for your configure command line.  We have an SMP chapter
>>> in the user manual.  Unfortunately, the automatic documentation generation
>>> doesn't work currently, so better build the docs from the sources.
>> Where can I find instructions on how to manually build the documentation
>> from source code?
> It seems that this is nowhere documented. I use this
> cd doc
> mkdir b-doc
> cd b-doc
> ../configure --enable-maintainer-mode
> make
https://git.rtems.org/rtems/tree/doc/README#n26
