Booting images with uboot get stuck after execution of rtems
Tue Dec 15 23:06:26 UTC 2015
On 12/16/15 09:52, Jan Sommer wrote:
> Hi,
> I currently try to load my rtems binaries through uboot and tftp for the raspberry pi, because I am getting tired of the sd-card switching.
> I used this tutorial to build uboot from Stephen Warren's branch: http://elinux.org/RPi_U-Boot
> uboot boots fine and the tftp transfer works too.
> However if I try to boot the transferred image it get stuck after a short time (see below).
> If I copy the same image file onto the sd-card and run it directly (without uboot) it executes normally.
> I used the commands from https://rtime.felk.cvut.cz/hw/index.php/Raspberry_Pi#RTEMS_Boot_with_use_of_U-boot to create the image file:
> arm-rtems4.11-objcopy -R -S --strip-debug -O binary ticker.exe ticker.bin || exit 1
> cat ticker.bin | gzip -9 >ticker.gz
> mkimage -A arm -O rtems -T kernel -a 0x00008000 -e 0x00008000 -n "RTEMS" -d ticker.gz ticker.img
> Do I need to do something else before booting, e.g. set some environment variable?
> Best regards,
>      Jan
> U-Boot> dhcp ${kernel_addr_r} ticker.img
> Filename 'ticker.img'.
> Load address: 0x1000000
> Loading: *\0x08#####
> \0x09 1.5 MiB/s
> done
> Bytes transferred = 69269 (10e95 hex)
> U-Boot> bootm ${kernel_addr_r}
> ## Booting kernel from Legacy Image at 01000000 ...
>     Image Name:   RTEMS
>     Image Type:   ARM RTEMS Kernel Image (gzip compressed)
>     Data Size:    69205 Bytes = 67.6 KiB
>     Load Address: 00008000
>     Entry Point:  00008000
>     Verifying Checksum ... OK
>     Uncompressing Kernel Image ... OK
> ## Transferring control to RTEMS (at address 00008000) ...
> *** CLOCK TICK TEST ***
> TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
> TA2  - rtems_clock_get_tod - 09:00:00   12/31/    <--- Execution gets stuck
Does the test finish?
Sometimes a reset may result in console output being lost. If you add a
sleep at the end of the test for a while do you get all the output you
expect?
