Booting images with uboot get stuck after execution of rtems
Jan Sommer soja-lists at aries.uberspace.de
Wed Dec 16 07:34:42 UTC 2015
Am Wednesday 16 December 2015, 10:06:26 schrieb Chris Johns:
> On 12/16/15 09:52, Jan Sommer wrote:
> Does the test finish?
> Sometimes a reset may result in console output being lost. If you add a
> sleep at the end of the test for a while do you get all the output you
> expect?
The test should run for at least 30 s, so I don't think the program is terminating before it could write its data to the uart.
Do you (or someone) have a working raspberry/uboot-setup which you could share for testing?
> Chris
> users mailing list
> users at rtems.org
