Zynq Ethernet driver
Davide Viti zinosat at tiscali.it
Wed Dec 2 09:07:43 UTC 2015
Hi Sebastian,
To run the application, I'm using a recent version of upstream uboot, which
assigns a random mac address:
Warning: Gem.e000b000 (eth0) using random MAC address - c6:4c:58:c9:e6:c4
the dhcp01.exe application, seems to correctly inherit such address from
the boot:
info: dhcpcd: version 6.2.1 starting
info: dhcpcd: DUID 00:01:00:01:e9:6d:a1:80:c6:4c:58:c9:e6:c4
and also the wireshark traces show that the mac address is used during the
DHCP negotiation.
I compared the working setup (qemu) with the microzed setup and noticed the
following:
miibus0: <MII bus> on cgem0
devctl: ? at phyno=0 oui=0xac2 model=0x1d rev=0x1 on miibus0
does that '?' mean that the network card is not recognized?
Regarding the crash, here is what appens when I run the application:
zynq-uboot> bootelf
data abort
pc : [<3ff960bc>]       lr : [<f8c90314>]
reloc pc : [<040350bc>]       lr : [<bcd2f314>]
sp : 3f33dd3c  ip : f1b83000     fp : 3f352440
r10: 00000001  r9 : 3f340ef8     r8 : 00000000
r7 : 00000028  r6 : 00000004     r5 : 00000000  r4 : 001b27a8
r3 : d0030f00  r2 : d0030f00     r1 : f1b83000  r0 : f8c90318
Flags: NzCv  IRQs off  FIQs off  Mode SVC_32
Resetting CPU ...
resetting ...
I managed to narrow down a little bit the problem:
as I said previously, if I remove the definition of DEFAULT_NETWORK_SHELL
the problem does not happen; I've noticed that this is the relevant part:
#define CONFIGURE_SHELL_USER_COMMANDS \
  &bsp_interrupt_shell_command, \
  &rtems_shell_BSD_Command, \
  &rtems_shell_HOSTNAME_Command, \
  &rtems_shell_PING_Command, \
  &rtems_shell_ROUTE_Command, \
  &rtems_shell_NETSTAT_Command, \
  &rtems_shell_IFCONFIG_Command
"bsp_interrupt_shell_command" and "rtems_shell_BSD_Command" do not cause
any issue, but whenever I include any of the other commands I see the
problem happening: which leads me to guess that there's something related
with the inclusion of the commands of the "net" category (happens only on
the target board and not on qemu)
regards,
Davide
URL: <http://lists.rtems.org/pipermail/users/attachments/20151202/24b28a5d/attachment-0002.html>
