Zynq Ethernet driver
Sebastian Huber
Wed Dec 2 17:51:55 UTC 2015
Hello Davide,
I guess you have a general memory corruption problem. If you add the shell commands, then you change the memory layout and a visible effect appears or not. So this is something for a debugger.
You have to make sure that the PHY is correctly initialized. For this you may have to register a driver. See nexus-devices.h for examples.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20151202/136cbb07/attachment-0002.html>
